Yes, but why would you want one? That tranny is bullet-proof...but it is also very heavy, the most inefficient tranny in GM's line of automatics, and does not have an overdrive range.
If you only want it for drag racing, and it is coming to you "free", maybe it would be a good idea. Otherwise, re-think which transmission you should install.
Thanks for the input guys. I'll keep what I have and just fix the leaks and save a few bucks.👍
Take it to an auto trans specialist and suggest have him put a Transgo kit in it. It will shift better and the clutches will last longer with normal driving.
The 400 is a great trans, but the TH350 with a good kit in it will be as good as a TH400 and a hell of a lot cheaper to upgrade than to replace with a 400. The tailshaft length, output yoke, crossmember will all have to be changed if you go to a 400.
Doubt that the clutches will last longer with a shift kit. Hard shifts eat up clutch disc material. The shift strategy used by the manufacturer will provide the longest life for normal use (including the occasional 'hot foot').
Now, if you are drag racing the car a bunch, a shift kit might be the right thing to do.
