Cornfused!!!!!!!!!
Old Oct 16, 2013 | 11:23 PM
Plasticfreak's Avatar
Plasticfreak
Default Cornfused!!!!!!!!!
Please help with this problem....I have a 75 with air and bought a new heater control valve but can't find the white vac line that connects to it.....it has to come out of the firewall somewhere! Thanks in advance!
Old Oct 16, 2013 | 11:28 PM
jnealg's Avatar
jnealg
I think the vac lines come out right behind the distributor in a 4 hose (i think) grommet. the grommet is at an angle towards the right side in mine
Old Oct 17, 2013 | 08:03 AM
minitech's Avatar
minitech
white tubing
Old Oct 17, 2013 | 10:45 AM
langg's Avatar
langg
Mine is a rubber hose that goes thru the firewall along with two or three others. It comes out in a grommet that is on the left side of center somewhat left of the distributor.
Langg
Old Oct 17, 2013 | 02:39 PM
Plasticfreak
Thanks.....gonna look!
Old Oct 17, 2013 | 03:12 PM
oledave60's Avatar
oledave60
My 75 has two tubes coming thru the firewall and neither is white. The solid black on the upper left connects to a vacuum source either on the manifold or carb. The one on the lower right connects to one with a green stripe and goes back thru the firewall into the wiper area and connects to a fresh air door. As you can see both of mine have been spliced due to hungry rats.
Old Oct 17, 2013 | 06:08 PM
ezobens's Avatar
ezobens
From what I've been able to determine, the HW valves were installed from 68-70 and then re-appeared in 76.
I don't think 72-75 had them (not sure about 71) so you won't find the white hose. What confuses things is that most parts vendors sell valves for all these years even though AIM and the shop manuals don't show them installed or the white hose for them.
Old Oct 17, 2013 | 06:24 PM
Plasticfreak
Well...what should I do now?
Old Oct 17, 2013 | 06:36 PM
ezobens's Avatar
ezobens
Did you have one originally on your car?
If so, it should have had the hose connected?
If you have a valve and no sign of a hose, it sounds like someone may have installed one previously and realized there was no hose either-
In any case, the valve is worthless without the vacuum source as it will always remain open.
What you could do is tap into the (green) line that goes to the plenum valve in the cowl and that way, the valve would close anytime the A/C was set to 'MAX' or 'Recirculate', which is essentially all the white hose does anyway.
Old Oct 17, 2013 | 07:08 PM
langg's Avatar
langg
Guess I didn't pay enough attention to the original post. My 75 did not originally have a water shut off valve connected to the a/c system. I added the valve and installed a second vacuum valve like the one used for the headlights under the dash, ran a hose out through the grommet to connect to the valve. Since I installed the water shut off, I have only opened it once.
langg
Old Oct 17, 2013 | 07:37 PM
Plasticfreak
The fellow who had the car before me had a manual shut off in between the heater hoses I thought the original was broken and he replaced it with that one. I can't believe they changed things around for a few years and went back to the original setup. The person who sold the heater valve to me said it was the correct one for the car.....now I'm wondering..................
Old Oct 17, 2013 | 07:47 PM
jnealg's Avatar
jnealg
my 75 had a vac valve in it too. I swapped for a manual one. My vac lines are not color coded either.
is yours black plastic with two hose connections and a vac connection on top? thats mine.
Old Oct 17, 2013 | 08:05 PM
dochorsepower's Avatar
dochorsepower
No, the '75's didn't have a shutoff valve. That's why most owners like me disconnect or block the heater hoses to cool down the interior.
Old Oct 17, 2013 | 08:36 PM
Plasticfreak
No mine is a brass Everco one but almost like yours,as for DocHorsepower,How did you block off the heater hoses? Didn't that screw up the A/C?
Old Oct 17, 2013 | 09:42 PM
scottyp99's Avatar
scottyp99
Cornfused? Sounds like what you experience when you get lost in a cornfield! BTW, Ted Nugent rocks!!!!!
Scott
Old Oct 17, 2013 | 09:59 PM
Plasticfreak
Yes he does!!!!
Old Oct 17, 2013 | 10:27 PM
babbah's Avatar
babbah
Scott
He Rocks!
To Cornfused!!!!!!!!!
