Zero gap 2nd ring dyno test(old HR article)
Old Jul 5, 2002 | 12:38 PM
Matt Gruber's Avatar
Matt Gruber
Default Zero gap 2nd ring dyno test(old HR article)
if you are building a motor, you may want to read the 3-94 Hot Rod article, page 70.
They gained 9 hp from 3500-6000 on a 414hp SBC,
and cut blowby by 20%
i'm going thru my old mags; saving good articles;making the trash man happy with the rest :hat
Old Jul 6, 2002 | 01:45 AM
subboz's Avatar
subboz
Default Re: Zero gap 2nd ring dyno test(old HR article) (drives61)
Thats some big money for the rings though. I looked into them when building my motor and at 100+ for file fit Zero Gaps it was just to much to stomach for 9 horseys when its much easier to make that up in other areas.
Old Jul 6, 2002 | 08:56 AM
Matt Gruber
Default Re: Zero gap 2nd ring dyno test(old HR article) (subboz)
subboz
i agree. i'm too cheap too!
But, i did buy speed-pro file fit rings.
The above test used .018" top ring gap. i used .012", so when warmed up, my top gap is maybe .001-.002"
To convince me, they would have to re-test with a .012 gap.
Also they did normal rings on the first dyno, then zero's after 10 more runs. Some of the gain could be from breakng in. I would need to see a re-test with the normaal ring AFTER the zeros.
Recently there is conflicting data showing more power with a WIDER 2nd gap :confused:
Whenever :confused: i spend less!
I posted the info so somebody could look it up, and form their own conclusion, which could vary for sure :smash:
Old Jul 6, 2002 | 03:08 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Warm gap of .001-.002 YIKES! You got more nerve than I do.
That would ideal if you could be sure it would get no smaller.
End gap butt is an unpleasent situation :smash: I can attest to that personally :jester
Old Jul 6, 2002 | 03:15 PM
Matt Gruber
Default Re: Zero gap 2nd ring dyno test(old HR article) (yellow 72)
i got that tip from Smokey Yunicks' Power Secrets book.
he said he ranthe Daytona track .012.
I figure if it worked for him, must be OK.
ONLY for forged :smash: pistons.
Gives an extra 10-25 HP :yesnod:
To Zero gap 2nd ring dyno test(old HR article)
