"H" PIPE OR NOT
Old Jul 3, 2002 | 12:04 PM
Ken74Conv's Avatar
Ken74Conv
Default "H" PIPE OR NOT
I finally got my car on the road with a new ZZ4 and Hedman Headers.
Friday I'm going to the muffler shop to have the headers hooked up to the 2 1/2" Ravin mufflers I had put on last year. I am interested in the increased performance you supposedly get from on "H" pipe but I don't want to muffle the sweet sound the mufflers now give me.
Any body with experience in this area please advise.
Thanks,
:cheers:
Old Jul 3, 2002 | 12:07 PM
Ganey's Avatar
Ganey
Default Re: "H" PIPE OR NOT (Ken74Conv)
Yes helps power. Also called a balance pipe, get the H or X, basically the H w/o pipe.
Old Jul 3, 2002 | 12:11 PM
vettesite's Avatar
vettesite
Yep! :yesnod: It helps balance the pressure between both pipes and will increase power/torque. The exhaust note will be deeper, have less resonance and get rid of that raspy sound.
BB wowbagger's Avatar
BB wowbagger
Default Re: "H" PIPE OR NOT (Ganey)
It will muffle the sound a little but give you some more torque in the lower rpms.I`m still working on my X pipe.This must be the the biggest PITA i`ve discovered so far.... :smash: :cheers:
Old Jul 3, 2002 | 12:25 PM
ZiVvmO's Avatar
ZiVvmO
Default Re: "H" PIPE OR NOT (BB wowbagger)
it may be a PITA but once you get it in you will love it. everyone i know who has an X pipe seems to be very happy with it. I would recommend an X over an H.
Old Jul 3, 2002 | 12:37 PM
Alwyn678's Avatar
Alwyn678
Default Re: "H" PIPE OR NOT (vettesite)
[QUOTE]Yep! :yesnod: It helps balance the pressure between both pipes and will increase power/torque. The exhaust note will be deeper, have less resonance and get rid of that raspy sound.
Exactly...My car sounds Fantastic......I wanted an x but we could not make it fit without hanging too low
Old Jul 3, 2002 | 02:20 PM
Ken74Conv's Avatar
Ken74Conv
OK! I'm convinced. "H" pipe it is.
Thanks for your help.
:cheers:
Old Jul 3, 2002 | 03:09 PM
BB wowbagger
Nothing to speak about...:cheers: :cheers: :yesnod:
Old Jul 3, 2002 | 03:25 PM
Steve Grodin's Avatar
Steve Grodin
H pipe makes a difference for all the above mentioned reasons.
Old Jul 3, 2002 | 05:08 PM
Wardog's Avatar
Wardog
Default Re: "H" PIPE OR NOT (Steve Grodin)
Some shops will want to put in a smaller diameter pipe between the two main tubes. I am not sure if this helps power, but you may want to be ready for the question when you go to the shop.
Old Jul 3, 2002 | 08:27 PM
Chris O''s Avatar
Chris O'
Default Re: "H" PIPE OR NOT (Wardog)
H pipe = good! Should be smaller diameter than main pipes.
:cheers:
Old Jul 3, 2002 | 09:36 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: "H" PIPE OR NOT (Chris O')
i understand the H pipe but what is an X pipe?
Old Jul 3, 2002 | 10:37 PM
Ryan77's Avatar
Ryan77
Default Re: "H" PIPE OR NOT (SIGNGUY)
I would go with the X pipe, it will flow better, if you think about it a 45 degree angle in the X pipe makes it flow better and easier compared to the 90 degree angle of the H pipe. I will be putting headers and an X pipe on my '77 at the end of the month. But, an H pipe is definately better than no balancer at all.
Signguy-- An X-pipe is exactly what it says, the two exhaust pipes cross through each in the shape of an X, it does the same job as an H pipe, but flows a little bit better and of course is different shaped.
Old Jul 3, 2002 | 11:00 PM
Alwyn678's Avatar
Alwyn678
Default Re: "H" PIPE OR NOT (Ryan77)
Good luck getting it to fit properly .....3 exhausts shops could not make it work for me....but the H and 2.5's are GREAT FLOWING
Old Jul 3, 2002 | 11:53 PM
gdh's Avatar
gdh
Default Re: "H" PIPE OR NOT (ZiVvmO)
Did you have any problems fitting it to your '70? May look into fabricating an X in the fall.
Old Jul 4, 2002 | 06:51 AM
BB wowbagger
Default Re: "H" PIPE OR NOT (gdh)
Maybe this could throw som light on the subject... http://www.boyleworks.com/ta400/psp/exhaust.html
Old Jul 4, 2002 | 10:52 AM
74Coupe's Avatar
74Coupe
OK, Should the H-pipe be the same Dia as the exhaust pipes or should it be a smaller Dia? If smaller how much smaller EX: 2 1/2" Pipes with 2 1/4" H-pipe?
Please explain :confused: :confused:
To "H" PIPE OR NOT
Old Jul 4, 2002 | 12:20 PM
Garson's Avatar
Garson
I had to do some transmission work on a Vette with an H-Pipe. We had to cut the exhaust to allow access to remove the trans. Make sure that the h-pipe does not get in the way of rear leaf or trans work later on. I have seen the h-pipe with bolted flanges so the exhaust can be moved for future repairs........
Garson
Old Jul 4, 2002 | 01:23 PM
molchaser's Avatar
molchaser
Default Re: "H" PIPE OR NOT (Garson)
I put a 2" "H" crossover on 2 1/2" pipes. It made it easier to avoid Parking brake cables.
My theory is that the "H" is a pressure balancing device and there is not a need for a massive flow area.
I may be wrong, but it worked well for me.
As Lee Greenwood sings "God Bless the USA
:flag :flag :flag
Old Jul 4, 2002 | 06:45 PM
Darkness's Avatar
Darkness
Default Re: "H" PIPE OR NOT (molchaser)
Well side pipes don't have H or X pipe and they still run good, but the if an H pipe will increase power, good, get it. Now would it be anygood to put an H pipe in a side exaust, doesn't matter how the hell it would be possible, but would it increase power?
paul
