Rust Removal Method Question for Front and Rear Spring Restore
1. Is the Evaporust product safe to use on the springs?
2. Another option is that I found a plating company that says they can dip my parts to get them down to bare metal for me. I don't know what chemical or method they use to do this? Is anyone familiar with the methods/chemicals typically used by plating companies to prep parts for plating? Are these chemicals/methods safe to use on the springs?
Thanks in advance.
Roger
It won't cause any damage to your springs but don't expect them to come out all clean and shiny either - you'll still need to prime and paint your springs after.
If you had access to a glass beading cabinet you could also clean up your springs that way but I think it would be tedious (especially the coils) and in the end not much further ahead in terms of quality of finished product.
Just did mine last week.
Here's one of many sites that describe the process.
Simply scale your solution up to a 32 gal can.
The rear spring can go in one end at a time no problem.
I did my front stabilizer bar this way.
Tips: The Washing Soda works much better than baking soda you can get it at Walmart.
The parts will look no different when you remove them from the soak but when you apply the green pad & some water to them the rust simply wipes off - very little elbow grease required. I bought the green floor polishing pad because you get 5x the pad for the same price as a small 3 pack. Just cut it up into hand size pieces.
So here's all the supplies you need (and about 3 ft of pretty much any size wire to connect the rods together).
Assembled and ready to go in just 10 min (nothing fancy).
Part in the cauldron (you can see the charger connections)
Some before and after pictures (I soaked most parts over night and scrubbed them with pieces of the green pad & water for a couple minutes) These are all of my 72.
Roger
1. From reading the "How it Works" section of the Evaporust FAQ page, the mechanism it uses does not appear to cause hydrogen embrittlement. Thus, I believe that it is a possiblity. I'm concerned about it not producing the required natural finish look.
2. Glass bead blasting will not remove or otherwise damage the surface or the metal like sand blasting will.
We bead blasted a couple of other parts today in the cabinet resulting in an almost "aluminum" color to the metal. Is there a method to restore the desired natural finish look to the metal after glass bead blasting?
By the way, the coil springs appear to have only a light to moderate surface rust. My leaf springs have surface rust and some pitting in areas.
Any other input is appreciated.
Regards,
Roger
