Ticking fuel pump
Old Oct 24, 2013 | 06:55 PM
rafalc's Avatar
rafalc
Default Ticking fuel pump
So I've been trying to figure out for a while now where the damn ticking is coming from that I kept hearing from the transmission tunnel area. My original thought was the transmission so I kept checking the inspection cover, trimming and bending it to give more room.
Finally just now I opened the passenger side storage compartment and the ticking became louder. Grabbed a mechanic's stethoscope and started searching. I found it coming the strongest from the fuel line that runs right by the right storage box... kept going up the line towards the front of the car and found that the ticking is most likely coming from the fuel pump. The ticking speeds up as the revs go up, which makes sense as the pump has to work faster. At idle it eventually goes away and the stethoscope confirmed this as the ticking was not present anymore at the fuel pump or lines.
So the question is..... is the pump on the verge of going out? This sound has been present for the past 2 years. Should I rush to replace it?
Anybody experienced this before?
Old Oct 24, 2013 | 07:01 PM
TimAT's Avatar
TimAT
I've seen them make so much noise the knock sensor retarded the timing in 81+ model years. And run perfectly. (other than falling flat when the timing went away). How long it'll last is a good question. My answer would be it'll work right up until it quits. But the pump is a pretty easy change too. And $35-40 gets a brand new pump.
Old Oct 24, 2013 | 07:16 PM
rafalc's Avatar
rafalc
Any recommendations on which one to get? Any brand better than the other?
Also, any good write ups and tips on how to replace?
Old Oct 24, 2013 | 11:16 PM
mrmagrath's Avatar
mrmagrath
The ticking in my car was a lack of lubrication on the speedo cable. Sped up and slowed down as well. Good luck!
Old Oct 25, 2013 | 12:56 AM
TimAT's Avatar
TimAT
Unless you're running some big horsepower, not a thing wrong with the stock pump. My 69 has had a stock pump - from the original 427/435 to the crate L-88 and the current LS-7. Never had any problems running out of fuel. And the original pump was on the car until 2 years ago when I caught it showing a fuel stain from the vent.
As far as changing it, get a new hose from the frame to the pump- it's a molded hose so it needs to come from a vendor- the auto parts store hose will kink. The trick is the pushrod that drives the pump. There are a couple of ways to hold it up while you drop the new pump in. You can put a big wad of grease on the end of the rod, or there's a bolt in the front of the block you can remove and install a slightly longer bolt to hold it temporarily. Do a search for fuel pump and you can see the full threads on the how to part.
Old Oct 25, 2013 | 08:34 AM
rafalc's Avatar
rafalc
Is an electrical fuel pump a significant improvement worth getting?
Old Oct 25, 2013 | 11:16 AM
rafalc's Avatar
rafalc
So I am planning on replacing the rubber hoses and filters since this is a perfect opportunity.
Can someone tell me why nobody lists the filter between the pump and carb (the metal canister) for a '70? All I see is 68-69.
Old Oct 25, 2013 | 09:02 PM
gcusmano74's Avatar
gcusmano74
Two possible advantages:
One, the electric pump is remotely mounted, and the fuel line can be routed away from the hot engine. The three port mechanical fuel pumps allow fuel to flow through and bypass the stock pump to cool the fuel a bit, to address the problem of vapor lock.
And, two, you can hide a switch in the wire that powers the electric fuel pump, as an anti-theft device.
Old Oct 25, 2013 | 11:47 PM
TimAT's Avatar
TimAT
That is an ADD-ON filter, not factory installed. Someone cut the line and installed a filter in addition to the one the factory installed in the carb.
Good points- but from the posted picture, the pump installed has a return fuel line.
Old Oct 26, 2013 | 08:28 AM
lvmyvt76's Avatar
lvmyvt76
buy a new metal fuel line and get rid of that inline fuel filter, a disaster waiting to happen. Make sure there is a fuel filter in the carb.
Old Oct 26, 2013 | 01:17 PM
galeel's Avatar
galeel
why is the inline fuel filter a disaster?
Old Oct 26, 2013 | 02:07 PM
rafalc's Avatar
rafalc
OK need some help here, this has been driving me crazy for some time now.
When inspecting the ticking with a stethoscope:
--touching the fuel pump - almost nothing
--touching the fuel lines from the pump going towards the back of the car - almost nothing but you do hear the ticking
--fuel line thats routed over the wheel well frame section (not original lines), turning down towards the TArm pocket - no stethoscope needed.....loud and clear!!!
Would it still be the pump/rod? Why would the loudest ticking be at that one section of the fuel line only???
I am holding off with the pump replacement until I am able to somehow explain what is happening here....
Old Oct 26, 2013 | 03:43 PM
Dave Witman's Avatar
Dave Witman
I had this exact same issue with a 78 only when car was warm and at 2000rpm. Sounded like a problem with the right muffler. I installed a temp muffler on with no change. I finally raised car on lift and ran at 2000 rpm an knocking noise sounded like the fuel lines that run over the frame in the back. With a mechanics scope I located the loudest point which was at fuel lines noted above. I tried to shove rubber in between lines to insulate with no change. I finally put scope on pump and could hear noise but not as loud. I removed pump and the push rod was fine but there was a lot of slop in the fuel pump arm side to side. This was a new pump with maybe 50 miles on it. I replaced pump and guess what no noise. The noise is transmitting down the fuel lines. dave
Old Oct 26, 2013 | 03:58 PM
rafalc's Avatar
rafalc
Thank you Dave. This has been bothering me for a while. Good to see someone else experienced something similar and found the issue. I am still puzzled though why the ticking is so amplified at that portion of the line and almost nothing at the pump....
Old Oct 26, 2013 | 04:17 PM
LS4 PILOT's Avatar
LS4 PILOT
Sure your exhaust manifold gaskets are not leaking. Or a cable binding or gear tooth on cable somewhere ......just guessed without standing in front of car.
Best luck
Old Oct 26, 2013 | 05:30 PM
Panhead59's Avatar
Panhead59
Yeah, why no inline filter? I would think the more the better. As long as the lines and connections are fine, what's the issue?
Old Oct 26, 2013 | 09:46 PM
Super6's Avatar
Super6
I think it's the rubber lines and the joints on either side of the filter. There probably is a factory metal line and filter arrangement from the fuel pump to the carb. That would look better and be safer.
To Ticking fuel pump
Old Oct 26, 2013 | 10:09 PM
rafalc's Avatar
rafalc
Correct, there is a metal line and appropriate filter with fittings. But then again these inline filters with inlet/outlet made for rubber and rubber connectors are not unusual either....
Old Oct 26, 2013 | 10:44 PM
TimAT's Avatar
TimAT
It's so easy to install an inline filter correctly- cut the line in the appropriate place, drop an inverted flare nut over the tube, flare it and done. And no chance ever of the rubber line growing a pinhole and spraying fuel everywhere. If you want to really get fancy, flare it for AN-6 fittings and go that way.
Old Oct 26, 2013 | 11:28 PM
lvmyvt76's Avatar
lvmyvt76
the rubber lines get old, may leak and cause a fire, if the lines were flared, they won't (shouldn't) be a fire hazard. 2 fuel filters are not necessary, they lower the fuel pressure if they start to clog up, no need to have 2, 1 should be enough, that's what the came out of the factory with! The factory did not put rubber because of the fire hazard possibility. Ever seen a car go up in flames because of a gas leak???
