454 id #'s
Old Oct 25, 2013 | 07:57 AM
4 speed's Avatar
4 speed
Default 454 id #'s
Heads casting 'hi perf" 14092359
Block casting 1405445
block front pad stamp 8X 004
Old Oct 25, 2013 | 08:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you asking? You can often Google GM part numbers. 8X 004 on the pad is not a Corvette stamp.
Old Oct 25, 2013 | 08:06 AM
Revi's Avatar
Revi
You may have overlooked the "1" in the block casting number.
14015445 454 1978-1987 Two-bolt or four-bolt
14092359 1986-89 427 2.06 1.72 Open (truck engine)
Old Oct 25, 2013 | 08:16 AM
4 speed's Avatar
4 speed
is that tall deck 427, I didn't realize the heads were the same
Old Nov 1, 2013 | 02:05 PM
4 speed's Avatar
4 speed
would this engine be a good swap out in to my 73, just leaving it stock, or I can trade it off for a fresh 30 over short block 350. which I can add vortec heads and cam ?
To 454 id #'s
