Weird Turn signal help
Old Oct 27, 2013 | 09:33 AM
micks69's Avatar
micks69
Default Weird Turn signal help
1978 that every wire was massaged/cut/improved by PO whatever you want to call it. I have a new main dash harness.
Rear turn signals work fine as they should so turn signal lever should be good.
Front Right:
Rt marker flashes
Rt signal does not
Left signal Flashes
Left Marker flashes
Rt inside arrow flashes
Front Left:
Lft Signal flashes
Lft marker flashes
Rt marker flashes
Lft inside arrow does not illuminate.
I am open to all ideas on where to look
Old Oct 27, 2013 | 12:27 PM
hugie82's Avatar
hugie82
Sounds like he bubbaed the wiring in the front bumper. Look for splices at each corner or behind the drivers side head light. C3 vettes are know to have wires break at that point and he may have fixed it wrong. The easiest fix would be to replace that front harness.
Old Oct 28, 2013 | 11:36 AM
micks69's Avatar
micks69
Thanks worked it out. Bubba had been in the nose. Traced and straightened out wiring and all is good.
Old Oct 28, 2013 | 11:48 AM
hugie82's Avatar
hugie82
Glad too hear, thanks for the update!
To Weird Turn signal help
