Spark Plug Reading
Old Oct 28, 2013 | 07:25 PM
1978vett's Avatar
1978vett
Default Spark Plug Reading
Can anyone tell me what is going on with this plug ? Thanks
[IMG]http://i1149.photobucket.com/albums/o596/hozy5/000000001_zpsc
02ac8ab.jpg[/IMG]
Old Oct 28, 2013 | 08:28 PM
Ironcross's Avatar
Ironcross
Well its not the preferred tan-brown burn, but there is no oil problem...However on the electrode....I have never seen a orange color on the electrode.....Are you using an addative?
try another plug
Old Oct 28, 2013 | 08:34 PM
1978vett's Avatar
1978vett
try another plug
I ran a octane booster,, only one time..
Old Oct 28, 2013 | 09:16 PM
Brcmpbl's Avatar
Brcmpbl
Is that the only one like that?
Old Oct 28, 2013 | 09:46 PM
1978vett's Avatar
1978vett
Some of the other ones are like that also..
Old Oct 28, 2013 | 11:11 PM
Brcmpbl's Avatar
Brcmpbl
The cause is the octane booster you added. Unless you're running high compression (~10.5 points or more) you really don't need the stuff, etc. It is questionable whether it does anything at all.
Unlikely it caused any damage other than making your plugs look funny. Additives can mess with oxygen sensors in modern cars, but not most of ours.
Should be able to clean those up and reuse them if you want.
Old Oct 29, 2013 | 04:39 AM
Scott_M's Avatar
Scott_M
Cruising
This is definitely what plugs look like from using octane booster. Sends them orange. Light brown/orange deposits encrusted on the ground and/or center electrodes indicate ash deposits.
The fuel additives can add to the ash (octane booster) could be part of your problem.
However see how it appears to be concentrated more on one side. I dont want to raise any type of alarm but often when deposits are found on only one side of the spark plug core nose, it is usually considered to be a problem with the cylinder head (valve stem seals or valve guides) where it is concentrated most. When they are found on both sides of the spark plug, it is often considered to be a problem sealing at the piston rings.
Dont jump to conclusions. Clean them up or fit a new set. No octane booster or other fuel additives. Give it a good run & pop a couple of plugs from the cylinders you noticed were the most effected ones & see how they shape up.
Old Oct 29, 2013 | 09:45 AM
1978vett's Avatar
1978vett
Would I be seeing some blue smoke if it were valve guides/seals ?
Old Oct 29, 2013 | 10:52 AM
zwede's Avatar
zwede
Not necessarily. Most modern oils don't produce much smoke. It has to get pretty bad before you see visible smoke.
To Spark Plug Reading
