Speedometer
Old Oct 28, 2013 | 10:01 PM
69FASTFUN's Avatar
69FASTFUN
Default Speedometer
I need to change out the speedo gear in my transmission in my 69 4sp how hard is it to do. I have heard that you do not want the plastic gear to fall int the transmission does anybody have some instructions how to change it out.
Old Oct 28, 2013 | 10:14 PM
TimAT's Avatar
TimAT
The driven gear is easy. Right side rear of the trans, remove the cable and the 1/4" bolt (7/16 head) that holds the "bullet" in the trans. Rotate and pull gently and the bullet will come out. If you're really concerned with the gear falling into the trans, use a small needle nose pliers and hold onto it. You can see the end of the gear on the center of the bullet. Just don't use the pliers to pull the whole thing out.
Old Oct 28, 2013 | 11:30 PM
69FASTFUN's Avatar
69FASTFUN
How do I get the plastic gear out. I think that is the one that is damaged
Old Oct 29, 2013 | 01:57 AM
vetteguy22's Avatar
vetteguy22
It just pulls out after removing the speedo cable from the trani and the cover.
To Speedometer
