70 Electric Wiper Door
Old Nov 3, 2013 | 07:11 AM
Garys 68's Avatar
Garys 68
They don't carry the same one I bought any more. I went with the one with the greatest force. Typically they are slower, allowing the wipers to park before the door closes.
Originally Posted by SAMMAN
Thanks Gary, there are several different 2" stroke models with different force ratings. Would you know which one you used?
Sam
Old Nov 3, 2013 | 02:32 PM
SAMMAN's Avatar
SAMMAN
2016 C2 of Year Finalist
Thanks Gary,
Old Dec 20, 2014 | 08:26 AM
BMENZEL's Avatar
BMENZEL
6th Gear
Default C3 wiper door 1972 with AC
I finished the install of the wiper door actuator. I used a 2" linear actuator I bought off Ebay for $40.00. I drilled and tapped the end of the aluminum rod for a 5/16 x 18 tpi rh thread to accept a threaded stud that screws into the long factory hex adjustment nut. I cut 2 aluminum angles from Lowes stock and bolted them to the factory bracket the vacuum motor was attached to. The factory rubber bellows even fits over the actuator. For now I am using a separate DPDT momentary contact switch to operate the door. I may add relays etc later to work off the wiper switch. I plan to try to hide more of the actuator in the firewall later on but this mounting is OK for now.
Old Dec 20, 2014 | 09:11 AM
Garys 68's Avatar
Garys 68
Looks somewhat familiar....
So you kept the scissor mechanism and rod? I removed all that and connected the actuator to the arm that comes off the pivot rod in the wiper well. It moved most of the actuator into the well, but probably doesn't make it work any better.
If you wire to the wiper switch with relays, just be sure the actuator is slow enough that the door wont close before the arms park.
Old Dec 20, 2014 | 09:33 AM
ezobens's Avatar
ezobens
Do you have a link (or model / part number) for that actuator?
This arrangement will probably be easier to fit for my application vs the power seat motors that lie against the firewall.
Thanks!
Elm
Old Dec 20, 2014 | 12:13 PM
Richard454's Avatar
Richard454
Here's mine finished up-
DSCN4655 by richardhayes454, on Flickr
Here's the wiring-
wiperdoorcontrolREVISION by richardhayes454, on Flickr
And those wanted an actuator - here's some food for thought- a cable driven one- can use a longer cable-
DSCN4977 by richardhayes454, on Flickr
Old Dec 20, 2014 | 12:35 PM
Richard454's Avatar
Richard454
Here's an inexpensive way to "slow" the actuator down- it's a simple adjustable timer circuit- I think I got it for about $10 shipped.
Wire in door closing and it will delay the closing from a couple of seconds to a couple of minutes. Can be negative or positive triggered.
DSCN4978 by richardhayes454, on Flickr
Old Dec 20, 2014 | 09:26 PM
BMENZEL's Avatar
BMENZEL
6th Gear
Default here is the 2" actuator
Thanks!
Elm
http://www.ebay.com/itm/390587296997?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Dec 21, 2014 | 01:16 PM
Garys 68's Avatar
Garys 68
Wow, 225lbs? Kinda overkill, but that price is great.
Btw, have you guys seen this? Kinda pricey.
http://www.zip-corvette.com/68-72-el...rsion-kit.html
Old Dec 21, 2014 | 05:22 PM
ezobens's Avatar
ezobens
WAY pricey! Wow.. And not even an attractive solution at that.
Must be all solid gold components inside
Yeah, I've been looking around and even though you could probably get away with a 25# or less rating, the speed is what you need to watch for.
The lower capacity units are like 1" a second while these 225# units are between 10mm - 12mm per second, which would help avoid any contact with the wiper arms.
Old Dec 21, 2014 | 09:48 PM
BMENZEL's Avatar
BMENZEL
6th Gear
If you Google the above wiper door kit manufacture web site (there is a site that shows the inside of the $1.300.00 kit). It looks like the actuator is uses is identical to the one I bought on Ebay for $40.00 . They just wrapped it up in a big ol' aluminum/steel box.
