Need leaf spring help 70 base corvette
Old Nov 3, 2013 | 02:15 PM
eot52's Avatar
eot52
Default Need leaf spring help 70 base corvette
From everything I've been reading on the forum it sounds as though the way to tell if you're due a new set of leafs is if yours are laying flat or broken. Mine appear almost parallel to the garage floor and none appear broken.
I'm trying to stay as original as possible, within $ reason, and would like to know, since this is my 1st C3 and I've only owned it about 3 months and all of my vettes have been 1 C4 and 5 C5's, if there's any other tell tale signs I need to look for. I've no experience with new spring ride therefore I don't know how it should feel.
All I know is it's rougher than the C5's.
I do have new shocks on the rear and the fronts aren't very old.
Old Nov 3, 2013 | 04:49 PM
7t9l82's Avatar
7t9l82
the composite springs ride better.
Old Nov 3, 2013 | 05:44 PM
Alan 71's Avatar
Alan 71
Hi eot,
You can easily check the rear ride height which give you an indication if your rear spring is sagging.
It's a shame to replace it if it doesn't need to be replaced, plus, replacing the spring often causes new problems getting the car to sit at the proper ride height again.
The measurement from the ground to the center of the fender wheel arch should be right around 28". The size of the tires you're presently using may influence that dimension since they may be taller or shorter than the originals.
Regards,
Alan
Old Nov 3, 2013 | 06:17 PM
eot52's Avatar
eot52
Originally Posted by Alan 71
Hi eot,
Regards,
Alan
Thanks Alan,
I'm showing 27 5/8" Passenger side to 27 3/8" Driver side with 215/70r15 tires.
Old Nov 3, 2013 | 08:04 PM
SB64's Avatar
SB64
Default leaf spring
I just went through the spring thing on my 69. 7 or 9 leafs? My orig. spring was flat straight. The rear of the car was very low. Installed a new 7 leaf considered to be the f41 option and the car sit allot better. How are your trailer arms and shocks. Alan height range is correct.
good luck
Old Nov 4, 2013 | 08:43 AM
eot52's Avatar
eot52
good luck
Thanks for the reply. I have a 7 leaf. Shocks are new. What do I look for on the trailer arms? Was your height lower before the replacement and how much did it rise?
Old Nov 4, 2013 | 08:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...It's a shame to replace it if it doesn't need to be replaced...
eot52: based on your earlier posts, there is not much wrong with your car. Why not leave it alone?
Old Nov 4, 2013 | 09:15 AM
eot52's Avatar
eot52
That's what I am hoping for because believe me, I do not want to have to replace anything if I don't have to.
What brought this subject up is that I have a 78 Carter Carb, that I replaced with a correct carb, for sale and someone wants to trade me a new set of springs + $50 for my carb so I thought I'd try to determine if I might have a need for the springs before I made a decision on the swap. I don't have any knowledge on springs but since the forum is so full of info, thought I'd learn something here.
Thanks for your concern for my car. Believe me, I have even more concern, just don't have as much knowledge on C3's.
Old Nov 4, 2013 | 11:51 AM
SB64's Avatar
SB64
Default leaf
I agree with Alan on the height, you are close enough. Yes my car was very low in the rear. Unfortunatley I did not measure height. Car rose very close to 28" with new spring and all new rubber bushings. Any other 69 questions Iam ready thanks R
Old Nov 4, 2013 | 12:56 PM
Red Vert 02's Avatar
Red Vert 02
As others have said, the ride height on your car is fine. The 7 leaf spring if it is an F41 will ride harder than the standard spring as it has a higher spring rate. As for the spring being parallel to the garage floor, that is the way they are supposed to be. Close to flat from trailing arm to trailing arm. It all sounds good.
Old Nov 4, 2013 | 01:45 PM
eot52's Avatar
eot52
Thanks! That's the info I was looking for.
To Need leaf spring help 70 base corvette
