Hyperco VS VBP
Old Nov 3, 2013 | 06:58 PM
ssenay72's Avatar
ssenay72
Default Hyperco VS VBP
I currently have a 200# hyperco spring which is nice and all but since i put a new motor (zz383) it seems to squat alot more than it use to when i get on it. But the ride is nice. How different would a 300# vbp spring ride? QA1 shocks.
Old Nov 4, 2013 | 11:43 AM
Priya's Avatar
Priya
I bought the Hyperco 200 lb easy ride spring a couple of years ago and I still don't have it in the car. Glad to hear it gave you a nice ride, that's what I'm after. I believe my car now has a 300 lb spring and I'm not happy with the ride.
Old Nov 4, 2013 | 11:49 AM
mrvette's Avatar
mrvette
You guys must have golden butts or something, I have a VBP 360 rear spring, with Bilstein sport shocks, which were a HUGE ride improvement over the KYB's that were on there.....
Old Nov 4, 2013 | 03:16 PM
C3 Stroker's Avatar
C3 Stroker
... I have a VBP 380# rear spring, and I wish would I have bought a 420#. These springs are not as stiff as the numbers would indicate, compared to steel spring numbers. I have QA-1 adjustable rear shocks, and I can adjust the ride from very soft to very stiff. The shock adjustment affects the ride more than the spring#.
Old Nov 4, 2013 | 03:51 PM
Priya's Avatar
Priya
I wouldn't trust the majority of Corvette owners to know what a soft ride is. I think you both have pacebo effect, you expect your ride to be good so you think it is even though its harsh. When someone says their Bilstein sports give a soft ride that's a clue that they're out of touch. I don't buy that a fiberglass spring of 360lb is more "compliant" than a steel spring of 360 lbs - the 360 lb measurement is a measurement of how compliant a spring is, a 360 lb steel spring is just as compliant as a 360 lb fiberglass spring. There's no such thing as a spring taking the same weight to deflect and yet somehow being softer, that's just cognitive dissonance.
Old Nov 4, 2013 | 04:47 PM
C3 Stroker's Avatar
C3 Stroker
......understand your point, softness is a subjective thing. I'm talking sports car softness, not Cadillac softness. But a composite spring rides differently than a steel spring of the same weight. I've had both. The composite will bounce back differently (feels like less), so a higher number# will feel the same a steel with a slighter lower#.
The OP wants to eliminate some of the squat on acceleration with the 383 engine. You need quite a spring to do that. VBP recommends a 360# for a performance small block, or average big block. A 300# doesn't come close. Yes, it's firmer than a 200#, but it won't get the job done without stiff shocks.
To Hyperco VS VBP
