Wipers
Old Nov 3, 2013 | 07:50 PM
corvetteman72's Avatar
corvetteman72
Default Wipers
I have a 72 corvette. New wiring harness. New wiper motor but wipers dont work. I bench tested the motor. Its good. I get power to the limit switch but no power to the main red wire that connects to the wiper motor. Im puzzled on this. Shouldnt there be 12 volts to this wire. Ive turned the switch under the dash. I also have a new wiper switch but there isnt a ground there. Could this cause me bot to get 12 volts to the main red wire
Old Nov 3, 2013 | 08:58 PM
Revi's Avatar
Revi
Have you checked the position of the wiper door safety switch?
Old Nov 4, 2013 | 01:44 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Fuse good?
Old Nov 4, 2013 | 02:38 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you are getting power going in at the limit switch, with the door open you should get power out. If you don't then I'd take a hard look at the limit switch.
To Wipers
