Brake Issue on Re-assembly
Old Nov 3, 2013 | 11:00 PM
wayneyada's Avatar
wayneyada
Default Brake Issue on Re-assembly
OK, the brakes worked fine on my '74 C3 when I drove it into my garage. Had to disconnect the rear brakes & remove the rotors so I could work on another another project. When I got done with the project, I put it all back together, bled both back lines (did fronts as well), and now my brake pedal goes to the floor. Re-checked everything. Even re-bled them - no air bubbles, steady flow, kept master cylinder full . . . but now have no pedal.
Any thoughts?
Thanks in advance.
Wayne
P.S. I noticed there are bleeder valves on each reservoir of the master cylinder. Do those need to get bled? Why are they there?
Old Nov 3, 2013 | 11:38 PM
GRipp 73's Avatar
GRipp 73
Hi Wayne,
A couple of questions to help you get some educated answers back.
Power or Manual Brakes?
Did you disconnect the calipers or any brake lines when you changed out the rotors?
What is your process for "bleeding" the brakes?
Did the master ever go empty?
Do you know how old the rubber hoses are?
Old Nov 4, 2013 | 12:09 AM
wayneyada's Avatar
wayneyada
SEE ANSWERS BELOW:
Power or Manual Brakes? POWER
Did you disconnect the calipers or any brake lines when you changed out the rotors? YES, TOOK CALIPERS WERE OFF THE ROTORS AND DISCONNECTED FROM SYSTEM AT RUBBER HOSE.
What is your process for "bleeding" the brakes? INITIALLY, I WAS USING A HAND VACUUM PUMP WITH AN INLINE CANISTER TO COLLECT FLUID. WHEN THE PROBLEM STILL PERSISTED, I BROUGHT MY WIFE OUT TO ASSIST FROM THE COCKPIT. AS SHE WOULD HOLD THE PEDAL DOWN, I WOULD OPEN THE BLEEDER VALVE & CLOSE IT BEFORE SHE WOULD LET THE PEDAL UP. WE REPEATED THAT PROCESS UMPTEEN TIMES, UNTIL I WAS CERTAIN THERE WAS NO AIR BUBBLES AND THE FLUID WAS STEADY.
Did the master ever go empty? YES, AND RE-BLED LINES FOLLOWING.
Do you know how old the rubber hoses are? PRETTY OLD, BUT THEY DID NOT APPEAR TO BE LEAKING.
Old Nov 4, 2013 | 05:59 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I'd put my money on the master having a bit of air.
Some say they can be bled on the car, but I've always done it on the bench...
Old Nov 4, 2013 | 06:05 PM
7t9l82's Avatar
7t9l82
crack the bleeders on the m/c. bleed the inner rear first outer rear second. gravity bleed works well for me.
Old Nov 4, 2013 | 08:10 PM
lvmyvt76's Avatar
lvmyvt76
in what order did you bleed the brakes(front right first etc.) did you open up the correct bleeder on the caliper? any air coming out?? The master has to have all the air out to properly bleed the rest. M/c could of gone bad(probably not, but maybe). have to bleed in proper sequence thou!
Old Nov 4, 2013 | 09:00 PM
7t9l82's Avatar
7t9l82
it really doesn't matter which wheel you bleed first or otherwise except the rear calipers need to be bled inner first.
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Lots of opinions and success stories on how to properly bleed the brakes on a Corvette. Just search for "bleed brakes". I do it using the gravity method and start at the right rear, left rear, right front, left front doing one at a time. Keep the MC full at all times. Never had much luck bleeding the MC on the car but I see that you could. Sometimes when installing brand new calipers I would ask for assistance from the co-pilot to pump the brakes just to speed up the process. Otherwise, I always have good luck with the gravity method.
I also use a rubber mallet to loosen any residual bubbles in the calipers as I go. A few taps just to break the air bubbles free is all you need.
Old Nov 4, 2013 | 09:15 PM
robert.sperry's Avatar
robert.sperry
The rears have an inner and an outer bleed fitting on each side and both need to be bled. Did you bleed both fittings on each side?
Old Nov 5, 2013 | 12:09 AM
wayneyada's Avatar
wayneyada
No, didn't have a clue about two bleeders on each of the rears. Only did the outer ones as they were obvious! As mentioned earlier, I am new to Corvettes. I did first read Haynes' manual re the bleeding, and he mentioned nothing about that. However, I just reviewed it again, and Haynes says that 78-82 have double-bleeders in the rear but 68-77 do not. Can anyone either confirm or deny that? That's confusing since mine is a 74.
Anyway thank you very much for mentioning what most probably assumed that I knew.
Having said that, I will go back to square-on on the bleeding. If I were going to bleed the master cylinder too (bleeders ARE on each reservoir), I presume I should do that first??
Thanks again to those who responded. It is much appreciated.
Old Nov 5, 2013 | 08:33 AM
lvmyvt76's Avatar
lvmyvt76
throw that Haynes book away!!!! NOT GOOD ON CORVETTES. Questions like brake bleeding can be answered here and much correctly
Old Nov 5, 2013 | 11:46 AM
Brcmpbl's Avatar
Brcmpbl
"I just reviewed it again, and Haynes says that 78-82 have double-bleeders in the rear but 68-77 do not. Can anyone either confirm or deny that? That's confusing since mine is a 74".
That's incorrect. They all have two bleeder screws on the rear calipers, an inner and an outer, both at the front of the caliper. Bleed inner first, then outer, starting at the passenger side rear, then driver side rear, then on to the front (where you go passenger side first, then driver). That's from the GM manual, paraphrased, and it has always worked for me.
Old Nov 5, 2013 | 12:35 PM
wayneyada's Avatar
wayneyada
Thanks for the insight. So what is the best shop manual?
Old Nov 5, 2013 | 12:36 PM
wayneyada's Avatar
wayneyada
Thanks for the confirmation. Will give it another try as soon as I pick up another quart or two of brake fluid :-)
Old Nov 5, 2013 | 02:10 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...what is the best shop manual?...
The GM chassis service manual.
Old Nov 5, 2013 | 05:04 PM
70BBvert's Avatar
70BBvert
A good friend of mine swears the proper order for Corvette as stated in the service manual is:
LR inner
LR outer
RR inner
RR outer
FL
FR
I haven't found it in there but he claims he has bled the brakes on many Vettes in this order & gotten a good pedal in one round. He has owned and built many mid years & C3's and is an NCRS mid year judge. So, another opinion, for what it's worth $.02
Good luck
Jim
Old Nov 5, 2013 | 08:30 PM
72LS1Vette's Avatar
72LS1Vette
If the master cylinder reservior emptied you will have to bench bleed the master cylinder or you will never get pedal pressure. You can do it with the cylinder on the car if you park on a slight incline and jack the back of the car up until the top of the master cylinder is level. Disconnect the brake lines and do a normal bench bleed and you should get better results when you bleed the rear calipers. A little less effort than taking the cylinder off.
If you haven't done it already this would be a good time to replace brake hoses.
Rick B.
To Brake Issue on Re-assembly
Old Nov 5, 2013 | 10:30 PM
lionelhutz's Avatar
lionelhutz
Not bleeding the inner half of the caliper is likely what the issue is.
When we did Dad's car we tore off everything but the main steel lines before blowing them out and replacing everything new. Then filled it and let it gravity bleed before a little pedal pumping and bleeding. The brakes work great. So, I'd think you are fine with the vacuum bleeding re-filling the master.
Old Nov 7, 2013 | 09:31 PM
wayneyada's Avatar
wayneyada
Not to sound like a total dummy here, but I have two questions:
1. What is the specific process for bench bleeding a corvette master cylinder. Never done it.
2. Everyone keeps referring to "gravity bleeding". Never heard of that either. What is the specific procedure. I've typically always just used a 2nd person to strategically depress/hold the brake pedal while I opened/closed bleeder valves.
Thanks for everyone's input.
Wayne
Old Nov 7, 2013 | 09:55 PM
lionelhutz's Avatar
lionelhutz
To gravity bleed just take the cover off the master and open the bleeder and wait until fluid starts running out.
Did you try bleeding all 4 screws on the rear calipers yet? If you've been able to pump fluid through the master by bleeding it then I can't see you needing to bench bleed. Typically, you can't get any fluid flow when you need to bench bleed.
