It sounds as if the rear brake calipers should be inspected to see that they have the 2 bleeder screws. On my vettes I know I have them. That may be part of the problem you are having with getting all the air out.
To gravity bleed just take the cover off the master and open the bleeder and wait until fluid starts running out.
Did you try bleeding all 4 screws on the rear calipers yet? If you've been able to pump fluid through the master by bleeding it then I can't see you needing to bench bleed. Typically, you can't get any fluid flow when you need to bench bleed.
Actually I decided to take some of the advice from this list and change out the rubber hoses before I do the bleed. And then of course I ruined one of the steel line fittings (been there since new I think), so am waiting for the replacement line to get here! Will respond back to this thread after it gets here next week. There's still LOTS of other things for me to do <g>. Thanks.
kdf
I'm sorry, I thought I'd mentioned that. Yes, the rears DO have both inners and outers.
OK, I'm back. Replaced all four hoses and one metal line, refilled master cylinder, bled it, and went thru bleeding sequence on rears (inners & outers) plus fronts. I used a buddy to help by sitting in car, pumping brake pedal and then holding down while I popped open bleeders and closed them. Did this many, many times. Went thru darn near 2 qts of new brake fluid and yet contine to see air in rears. Fronts seem to be ok with no visible air seen. But with rears, I see 1-2 cycles with no air, but then the next cycle produces air. I detect no fluid leaks anywhere in the system. I think I need to keep trying, but do so with no better results. Am thinking bad master cylinder???
All of the bleeding is done with engine off. During the process, we do start to get a hard pedal (approx 50% travel but when we start the engine (power brakes), the pedal goes almost to floor. Whassup w/that?
well, this should have been said before. it helps to tap on the calipers to break up the air bubbles and move them through. some may try to take exception to that but the guy who taught brakes at the G.M training centers told me that years ago.
