69 rear crossmember
Old Nov 4, 2013 | 03:22 PM
SB64's Avatar
SB64
Default 69 rear crossmember
I hope Alan sees this post , but anyone can help with pics of how far up the crossmember sits on those metal stubs that you bolt to. Is it flush is there a gap is the rubber cup smashed to the top.
Old Nov 4, 2013 | 03:24 PM
tracdogg2's Avatar
tracdogg2
There will be a small gap on top. The crossmember bottoms out on the inside where you can't see it.
Mike
Old Nov 4, 2013 | 03:34 PM
SB64's Avatar
SB64
Default crossmember
That what I thought. Car is sitting up way to high in back. Got to looking and noticed that it looks like the member is not up as far as it should be. Thanks
Old Nov 4, 2013 | 04:33 PM
Alan 71's Avatar
Alan 71
Hi r,
Yes, as Mike said there will be a small gap when the mounting bolt is fully torqued.
Regards,
Alan
This is still the original bushing.
Old Nov 4, 2013 | 05:40 PM
SB64's Avatar
SB64
Default 69 crossmember
Well I know I did not replace rubber cups. I don't have the same amount of rubber showing. I wonder what created such a height difference. I will be installing the 7 leaf spring which came with the car and removing the 9 leaf. I don't think that will matter but its what came with the car. Any thoughts anyone . Thanks Alan for the very clear pic. Thanks Mike
To 69 rear crossmember
