Heads
Old Nov 7, 2013 | 10:51 AM
  #41
71scgc's Avatar
71scgc
63mako
billla
Listen to these men.
Carter
Old Nov 7, 2013 | 11:24 PM
  #42
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default What color is the smoke?
Blue smoke is oil but white smoke is water and black smoke it fuel. U need to get a good diagnose first.
The L82 engines came with forged pistons, forged crank, performance cam. That motor with low miles (80k mi is very little for sb chevy) has great potential with just better heads and compression - much better than the L48 engine. If compression test shows bad valves but good rings then this would warrant new heads rather than just a vlv job. Good heads are so cheap now days - $1000 or less - that if you need better heads then buy them. If u cant afford $1000 heads then u need an economy car - not a performance car.
IMHO heads are easier to swap than the cam - 1 weekend should do it for even a beginner.
All you need is a compression test and if all cyls are above 140 psi and within 40 psi then rings/bottom end are ok, but if a low compression cyl improves after a squirt of oil then the rings are the problem. Dont forget to block open the throttle and have the engine as warm as possible. A leak down test would be more revealing but will need not only the tester but an aircompressor.
Make sure the vlvs/heads are the problem first. Then dont miss this opportunity to get some great performance for little investment. Chevy performance heads are as cheap as they get. If u cant afford chevy heads then u need to sell your chevy.
cardo0
Old Nov 7, 2013 | 11:42 PM
  #43
redwhitekat's Avatar
redwhitekat
I thought if compression gets better after a bit of oil then the rings are the problem. ???? I'm doing the test this Saturday
Old Nov 7, 2013 | 11:48 PM
  #44
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by cardo0
All you need is a compression test and if all cyls are above 140 psi and within 40 psi or a low compression cyl improves after a squirt of oil then the vlvs are the problem.
cardo0
If compression improves after squirting a little oil in the plug hole and rechecking it shows bad rings not bad valves. I like to see less than 10% variance between cylinders. Other than that Leakdown test is actually what I would go with.
Old Nov 8, 2013 | 12:04 AM
  #45
cardo0's Avatar
cardo0
I was surprised to find in my shop manual for my '94 camaro something like 40 psi is usable. So i continued to drive it with #8 that much lower than the rest. No oil burn let alone blue smoke or any real issues driving it that way. Finally changed that motor out when it was convenient for me.
Yes 10% is nice but hey, its a chevy.
Old Nov 8, 2013 | 02:15 AM
  #46
billla's Avatar
billla
St. Jude Donor '14
Compression doesn't really tell you anything about oil control - so the leak-down is the important test.
Note that this still doesn't really tell you about the engine's overall condition - you just have to decide. You pays your money and you takes your chances.
