C3 Front brake line crossover
Old Sep 9, 2018 | 03:51 PM
teamo's Avatar
teamo
Those pictures are pretty good. It does show the orientation of the clips as I was looking for. Thank you
Old Sep 9, 2018 | 04:24 PM
naramlee's Avatar
naramlee
see, a five year old thread is handy ^.^
Old Sep 11, 2018 | 03:21 PM
scottjamison's Avatar
scottjamison
One trick I figured out when building brake lines is to prototype the line with a coat hanger. Easy to bend and correct, then once it looks perfect, bend the brake line to match and you're set.
Old Jan 17, 2021 | 01:51 PM
jcnst1's Avatar
jcnst1
I know this is an old thread but hoping someone responds......how in the heck do you get a wrench on the bottom nut to remove the steel line from the brass distribution block? I've gone in through the wheel well and pretty sure I broke it lose, but space is so tight I can't get enough turns to unthread it. Did you have to remove something or use a different tool other than basic 1/2 wrench?
Old Jan 19, 2021 | 12:12 PM
vettebuyer6369's Avatar
vettebuyer6369
If you are “hoping someone responds” start a new thread rather than tacking a question onto an old one.
