1969 wiper door - help needed please
Old Nov 6, 2013 | 01:35 PM
my2ndvette's Avatar
my2ndvette
Cruising
Default 1969 wiper door - help needed please
I'm new to his forum (find it hard to find what I need)...my wiper door does not work. Looking for step by step directions on what to do to determine and fix issue. Thanks a bunch!!
Old Nov 6, 2013 | 02:07 PM
Revi's Avatar
Revi
Step 1. Will the wiper door open if you pull the by-pass **** under the steering column?
Old Nov 6, 2013 | 02:20 PM
MelWff's Avatar
MelWff
read these documents
http://willcoxcorvette.com/instructi...function_2.pdf
http://willcoxcorvette.com/instructi...-72_5_2009.pdf
Old Nov 6, 2013 | 04:58 PM
my2ndvette's Avatar
my2ndvette
Cruising
revi,
this may make sound quite dumb, but pulling the by-pass ****, should I see it open? Or does this just allow to get out of the car and pull it open by hand? I am asking this because lack of knowledge on this topic and that pulling the **** did not open it by itself.
So, lets say if did not work, what is the next step?
thanks!
Old Nov 6, 2013 | 05:12 PM
rponfick's Avatar
rponfick
There are two pull switches. One for wiper door and one for headlights. If neither does anything, see the Willcox references above.
Good luck. Ralph
Old Nov 6, 2013 | 05:33 PM
my2ndvette's Avatar
my2ndvette
Cruising
Thanks all!!
I will be back with more questions down the road...just working out a few little things with this car.
mark
Old Nov 6, 2013 | 05:34 PM
Alan 71's Avatar
Alan 71
Hi m2v,
When you pull the override the door should open by itself.
The wipers can't start until the door is fully open.
If you open the door by hand will the wipers work?
Is the **** between the 2 override switches turned?... it stops the wipers wherever they are. They won't move until the **** is turned again.
If the door won't open it's likely a vacuum problem...
If the wipers won't operate with the door fully open it's likely an electrical problem.....
Regards,
Alan
Old Nov 7, 2013 | 08:30 AM
Revi's Avatar
Revi
Originally Posted by my2ndvette
revi,
thanks!
Start your car, pull the right by-pass ****. The wiper door should open on its own. Since it looks like it didn't open on its own, try pulling the left by-pass ****, the headlights should pop open. Do they?
If the headlights do not open there could be numerous issues with your vacuum system. It could be as simple as the vacuum source from the manifold isn't hooked up to the vacuum tank, the vacuum tank is missing, nothing is hooked up, etc., etc..
Get a Mighty Vac and apply vacuum to the wiper door actuator. Does it pop up?
Old Nov 7, 2013 | 08:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...this may make sound quite dumb, but pulling the by-pass ****, should I see it open?...
Yes, provided you have a source of vacuum (engine running or reserve tank).
Opening and closing of the wiper door and the headlight doors is 100% vacuum.
To 1969 wiper door - help needed please
