how do I get my lights down??
Old Jul 7, 2002 | 12:43 PM
tworottiedogs's Avatar
tworottiedogs
Default how do I get my lights down??
Most of the hoses are missing. I know the simple solution is to buy the kit to repair them but it would be a waste because I want to switch to recessed lights in the future. Is there an easy way to get these things down. I pushed them up and they locked in that position.
Thanks in advance
[Modified by tworottiedogs, 11:44 AM 7/7/2002]
Old Jul 7, 2002 | 12:46 PM
lbell101's Avatar
lbell101
Default Re: how do I get my lights down?? (tworottiedogs)
You have to reach up from underneath and pull on the joint between the upper and lower parts.
Old Jul 7, 2002 | 12:47 PM
tworottiedogs
Default Re: how do I get my lights down?? (lbell101)
Thanks Larry,
What joint? I see an actuator with a spring that has a connector with a couple of wires. Something in there?
[Modified by tworottiedogs, 11:48 AM 7/7/2002]
Old Jul 7, 2002 | 12:53 PM
lbell101's Avatar
lbell101
Forward of that you should see a large headed bolt installed horizontally. That is the pivot point for the mechanism. If you pull that down it will unlock and come down. Just what your fingers!
Old Jul 7, 2002 | 12:59 PM
tworottiedogs
IT WORKED! Now explain why I didn't ask this question a long time ago.
THANKS>>>
Old Jul 8, 2002 | 12:47 AM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
LOL :lol: Yea that mechanism works kinda like a knee. It locks in the straight up position, but if you kick it in the joint from behind it will let loose.
Old Jul 8, 2002 | 01:01 AM
Stevo81's Avatar
Stevo81
Wow...thanks for asking! That is something way down on the list of things to be done, but that sounds quick and easy...
To how do I get my lights down??
