How long is yours ?
Old Nov 11, 2013 | 06:55 AM
Panhead59's Avatar
Panhead59
Default How long is yours ?
1969 BB car. Wiper actuator on firewall has a shaft going through firewall. That shaft connects to a "wiper actuator rod nut". That in turn is connected to a "link" that pivots. My link may have been broken off at some point and the rod nut is missing. I have only 4 threads on the link. Does anyone know how long or how many threads are on a good link? I just don't want to buy a new one if mine is the correct length. Thanks
Old Nov 11, 2013 | 10:30 AM
rponfick's Avatar
rponfick
Mine has about 4 threads showing, plus what would be under the locking nut. As I recall, there are quite a few threads screwed into the long nut attached to the linkage that goes through the firewall.
If your's is broken, that would be a job to fix, other than a replacement vacuum can assembly.
Ralph
Old Nov 11, 2013 | 10:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If the wiper door is opening and closing, size doesn't matter. Check the Note at View C.
Old Nov 11, 2013 | 11:55 AM
7T1vette's Avatar
7T1vette
That's what I've always been told: "Size doesn't matter...as long as it works."
Old Nov 11, 2013 | 06:03 PM
scottyp99's Avatar
scottyp99
That's just something that guys with short wiper actuator rods say.
Scott
Old Nov 11, 2013 | 09:05 PM
7T1vette's Avatar
7T1vette
Hey, if you're dealt a short actuator rod, claiming adequacy is all you have left!!!
Old Nov 11, 2013 | 10:46 PM
scottyp99's Avatar
scottyp99
Scott
Old Nov 12, 2013 | 08:12 AM
Panhead59's Avatar
Panhead59
I posted that my "actuator rod nut" is missing so of course the flap doesn't work. The shaft coming out of the actuator is also apparently stuck. It won't budge in or out with a tremendous amount of pressure. So I know I have to buy an actuator and the rod nut. My question is how long is the link that pivots? It is there, still riveted in place but looks like it may have been broken off since it only has 4 threads left on it. That is the question. Hope that is more clear.
Old Nov 12, 2013 | 08:15 AM
Panhead59's Avatar
Panhead59
Ralph's reply indicates that the link has 2-3 inches (most likely) of threads. Would that be a close guess?
To How long is yours ?
