As a 1980 L48, My car is approaching 34 years of age. One place where I would like to do a chassis refresh is the wiring harness.
Questions:
Can I do it (ie. do I need help?)?
Can it be done in sections?
How much has to come off of the car to install?
What are the pitfalls and gotchas?
Is it cost prohibitive?
What improvements can I leverage with a new harness (fuel injection, increased voltage?, LED lighting, etc.)
Are there competitors (LectricLimited) that are better at Corvette harnesses?
I'm considering install of a new dashboard in winter 2013/early 2014. This would seem to be the PERFECT time to attack the harness. I'm also planning to have the seatbelts rehab'd by the Snake Oyle outfit that rebuilds the buckles, installs new retractors and all new belts/webbing.
are you actually experiencing problems requiring a complete harness, if not, I would leave it alone.
You are right. I've just got some areas that I'd like to freshen with better connectors and leads (alternator, temp sender, Throttle position, lighter, analog clock, rear speakers...) most of the places where PO's and I have touched/hacked in the last 34 years and show signs of wear.
No need for the complexity and expense of even localized harness replacement.
