Oil Pressure
Old Nov 11, 2013 | 06:49 PM
Red Hot 71's Avatar
Red Hot 71
Default Oil Pressure
I have a 1971 C-3 w/small block 350 motor. Oil pressure stays @ 70 PSI. Is that normal or do I need to investigate why it is reading so high? I recently purchased the car & was told the motor was rebuilt 7-8 months ago. It does seem to be using a little oil. Do I need to be concerned?
Old Nov 11, 2013 | 07:12 PM
TimAT's Avatar
TimAT
Check your gauge to see if it's reasonably accurate. When the engine was rebuilt, they most likely installed a high volume/pressure pump if the gauge is close. Myself, I don't have a real problem with oil pressure like yours, but the rule of thumb 10psi/1000 RPM is not all bad. The downside to that high of pressure is the lower busing in the distributor takes a beating, not to mention the extra load on the cam and timing chain.
Using a little oil? How much is a little? Leaks? Exhaust smoke?
Old Nov 11, 2013 | 07:32 PM
billla's Avatar
billla
St. Jude Donor '14
Sounds like another high-volume, high-pressure oil pump...
Old Nov 11, 2013 | 07:49 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
My stock, low-mile '71 350 has 30-35 psi @ idle at operating temp.
I can see why there would be added wear on the cam and dist. bushing as mentioned above, as when I was priming the engine after sitting for 25+ years with a 1/2" drill, I was surprised how much power it took to run the stock pump. That drill got hot!
Old Nov 11, 2013 | 08:30 PM
TedH's Avatar
TedH
I recently replaced the high volume pump with a stock volume pump. It maybe dropped 10psi across the board.
When cold, it pegs at 70-80psi just like the high volume pump. Only difference I see is when it is warmed up, it drops to about 30psi at idle and would rarely drop below 40psi at idle with HV unit.
Overall, I didn't see a lot of difference. I still get 60psi at speed fully warmed up with stock unit. It is a Mellings M55 unit. The HV was an M55HV.
Only reason I swapped was warnings about using HV with my retro roller; Comp said to use stock volume oil pump. I think it has to do with not overwhelming the oil filter bypass and so the oil is getting filtered.
Old Nov 11, 2013 | 08:34 PM
TedH's Avatar
TedH
What type of cylinder heads are on the engine? I ask as I'm about to remove all of my rocker studs and apply thread sealant; my DART heads rocker studs thread into some of the intake passages and I am getting oil smoke. Down about 1/2 quart after a 2-hour drive with the wife on Sunday. That may be the source for your oil consumption if aftermarket cylinder heads.
Old Nov 11, 2013 | 08:43 PM
billla's Avatar
billla
St. Jude Donor '14
Melling High Performance pumps typically come with both a high- and low-pressure spring for the bypass built into the pump.
HV pumps create artificially high pressure, forcing the pump into bypass, by forcing too much oil through tight bearing clearances. Even without a high-volume pump, as long as the high-pressure spring is still in place, the oil pump will likely still put out relatively high pressures. If oil needs to be restricted to the heads, there are other means such as oil restrictor plugs.
http://www.melling.com/Aftermarket/High-Performance
Old Nov 12, 2013 | 10:38 AM
AZDoug's Avatar
AZDoug
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
There is a difference between high volume, and high pressure.
You can have a normal volume pump, with a high pressure bypass spring, like was used in the early Z28 motors #3848907.
High volume pumps have taller and or wider pump gears, and may, or may not be high pressure. pressure is determined by the bypass spring, regardless of volume.
I have used the Z28 pump for years, in two different motors (same pump), it runs 60-65 at speed, and perhaps 25 at idle. The normal pump would run perhaps 45 PSIG at speed, and have the same idle pressure
Doug
Old Nov 12, 2013 | 12:20 PM
oldschoolvette's Avatar
oldschoolvette
Step one= Is the oil pressure really this high? Is the meter or sending unit dodo?
Step two= Fix the indication problem and
or evaluate why the pressure is so high even when the engine is hot
Step three= address the high pressure issue and then
To Oil Pressure
