Holley carb
Old Nov 13, 2013 | 10:42 AM
corvetteman72's Avatar
corvetteman72
Default Holley carb
Can anyone tell me which holley carb will fit with the stock snorkel air cleaner in the 72 vette. I bought a vac secondary but the cleaner wont fit. I was told by some that the mech secondary will work and some say it wont. I was looking at the 6210. Needs to be a spreadbore
Old Nov 13, 2013 | 12:11 PM
hugie82's Avatar
hugie82
Are you using an adapter with your Holley or you are trying to find the old spread bore Holley with the Rochester bolt pattern?
Old Nov 13, 2013 | 12:14 PM
MelWff's Avatar
MelWff
the 6210 mechanical secondary was designed to be a direct replacement but the original Quad would be probably a better choice
Old Nov 13, 2013 | 12:45 PM
corvetteman72
Yea i want a direct fit. No spacer. I no longer have the original quad at this time. I would buy a new one but dont know who to trust
Old Nov 13, 2013 | 01:18 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
I know the Holley spreadbores by 4165 (DP) and 4175 (Vac sec). I had the 4175 and was able to make the 73 dual snorkel base fit by putting a dent in it where the diaphram sticks up above the carb base...if you have the 4160 DP carb it will definitely fit.
Edited for bad grammar and correct model for the DP. Thanks MelWff...bad mem!
Old Nov 13, 2013 | 02:53 PM
MelWff's Avatar
MelWff
It's not 4160 series it's 4165 series DP of which the 6210 list# is a member of. The 4160 series is a square bore series not spread bore.
http://www.summitracing.com/parts/hl...FdFDMgod9GsAIw
This video explains the two different series of carbs
Old Nov 13, 2013 | 07:25 PM
drwet's Avatar
drwet
I had the stock air cleaner from my '79 on my Holley for a while. I had to do major mods to the air cleaner base. I cut it out to fit over the carb and welded in some sheet metal to seal it. Worked great, except it was contributing to my heat soak problems so I finally shelved it in favor of an open element air cleaner.
Old Nov 13, 2013 | 08:54 PM
corvetteman72
Thanks for all the replies
Old Nov 13, 2013 | 09:00 PM
roadblock69's Avatar
roadblock69
I have used the Holley 6210 carb on several Corvettes and never had an issue with air cleaner fitment. I have always used the double pumper versions. The vacuum secondary version can create some conflict.
Old Nov 13, 2013 | 10:45 PM
Kid Vette's Avatar
Kid Vette
Holley Model 4165 series PN R6210-3
Old Nov 14, 2013 | 07:39 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Great carb. I put one on my 68 427/390. Felt like I bolted on 100 horsepower (my QJ was in bad shape). It's been a great carb and required no heroics to install.
Old Nov 14, 2013 | 09:25 AM
corvetteman72
Thanks for the info and pics. All i needed
To Holley carb
