Best reman quad
Old Nov 13, 2013 | 12:48 PM
corvetteman72's Avatar
corvetteman72
Default Best reman quad
Who out there sells the best reman quadrajet. I have a 72 small block 4 speed and need a carb. Cliffs says it will be 4 months before they will work on one. Anyobe with good luck from any online stores
Old Nov 13, 2013 | 01:08 PM
Revi's Avatar
Revi
If your into numbers matching, these are the possibilities for your car.
200 4-Speed Rochester MV4 7042203
200 4-Speed/NB2 Rochester MV4 7042903
200 THM Rochester MV4 7042202
200 THM/NB2 Rochester MV4 7042902
Otherwise I would find any period correct used qaudrajet and send it to Lars for overhaul.
Old Nov 13, 2013 | 02:31 PM
billla's Avatar
billla
St. Jude Donor '14
Everything you need to know is right here:
http://forums.corvetteforum.com/c3-t...lt-q-jets.html
It's better to wait for quality than buy junk off the shelf...
Old Nov 13, 2013 | 10:45 PM
wheatpj's Avatar
wheatpj
Sean Murphy Induction rebuilt my Quadrajet. Carb worked fine right out of the box. Turn around was a lot faster than Cliffs. I think it only took a couple of weeks. I fattened the mixture up some, but that's because I can't leave well enough alone. I got it too rich. The carb is now set about the way it came from the rebuild...it runs really good.
Old Nov 13, 2013 | 11:16 PM
John Holmes's Avatar
John Holmes
+ 1 on SMI. Good stuff done right.
Old Nov 14, 2013 | 08:26 AM
gcusmano74's Avatar
gcusmano74
Old Nov 14, 2013 | 10:21 AM
rponfick's Avatar
rponfick
Lars is "da Man".
Ralph
Old Nov 15, 2013 | 11:12 AM
lars's Avatar
lars
I've never seen a good off-the-shelf rebuilt Q-Jet sold by anybody. If you have a non-commercially-rebuilt used carb suitable for rebuilt, there is a small handful of builders who can set it up right for you. Cliff is very good, and so is Henry Olsen. I've also been known to set up a carb or two.
For some info on the subject, you can drop me an e-mail request for the following papers:
"Commercially rebuilt Q-Jet Problems"
"Used Q-Jet Screening Service"
"Services Information Tech Paper"
Lars
V8FastCars@msn.com
To Best reman quad
