2020 Corvette of the Year Finalist (track prepared)
C3 of Year Winner (track prepared) 2019
Originally Posted by diehrd
You can also run 2 at a time supporting 1100 or 1200 hp .
Or step up to the 2.0 system which is capable of 1200 as well. Not sure how well the dual carbs would fit under a stock vette hood.
That is the route I went. Dropped my car off at the shop yesterday to get it started. I offered a $200 bonus if they could get it done by Friday night of this coming week (dyno day on Saturday and I would like to have my car) so we will see.
I 've been running the EZ EFI retro-fit kit for several years now, very happy with it
Started out with an LT1 intake converted for use with the Gen 1 engine, and later swapped in a TPIS Miniram
Found out about this little gem,if you don't want to mess with the fuel lines.Sump should prevent fuel starvation on fast cornering with less than 1/4 tank.. http://www.summitracing.com/parts/edl-3605/overview/
diehrd, how did modify the return line at the 82 sender? Bulkhead connector of some sort then new hose into the tank?
A/N fitting , elbow , with a 3/8 copper line into tank , then just run the return along the frame rail where the OEM lines run.. It was the easiest and the least expensive way to go about it . I think I paid 100.00 shipped for the sending unit for the 1982 , EZ EFI in tank kit comes with a return hose and the a/n fittings are at pep boys usually .
And even of you need a newer tank I think your talking about 279.00 for a new fuel tank that fits the sending unit.
I found that part interesting but had a couple of issues/questions.
How doe the vent work? It appears it must use some kind of float or something to seal the vent once the sump is full and any air has been purged. I would be worried it leaks so the thing is dumping fuel onto the ground.
Where does a return line go? The thing has a fuel inlet from the mechanical pump a pressurized fuel outlet and a vent so no return line fitting.
It appears to be tailored specifically for use with their E-street EFI systems.
Google search "fuel injection surge tank". There are a few other options such as this;
Question for those using Fast EFI. What fuel pump did you use? In-tank or in-line? Did you use a stock tank without a sump? If so do you have any issues at low fuel levels? thanks
I used the 1982 Sending unit in my 1980 and installed the EZ EFI pump onto it , perfect fit no concerns of having 1/2 tank issues at all. I do not want to offer bad info but the 1982 tank .. look and see but it may fit most if not all c-3 models ,, if it does your under 400 for a tank and sending unit ....
The year or type of sending unit or even C3 Corvette gas tank have nothing to do with the fact that there is nothing to hold fuel around the pickup without a sump or baffling. I can almost guarantee that in lower fuel level situations, the pickup will become uncovered during cornering or hard acceleration and the pump will suck air.
Well maybe ,But I wont go around with less then a 1/4 tank myself.. And I am not racing I am a street car , so as valid as your point may be it really is not applicable to the application i am set up for or most members for that matter.
My point has absolutely nothing to do with street vs race cars, and how exactly do you know what is applicable for what applications for most members?!?!
I guess you don't really understand the importance of keeping an EFI fuel pump's pickup submerged in fuel. It isn't really a problem with a carb because the bowls hold fuel. There is no production EFI vehicle that does not use a sump or baffle of some sort in the fuel tank for good reason. This applies to the cheapest of econo cars up to the most expensive sports cars.
Maybe you should tell them that they are all doing it wrong!
. Just wondering, how did this tank work ok on a 82? Did that system use some sort of reservoir.
Point taken , it seams I will have to run the tank low , start hammering on it , take turns like I am at Indy and then suffer the consequences. Not saying your points are not valid but I am saying it works as it should and unless I run low on gas I am not going to have an issue.
