How long Will Gas Last ?
Old Nov 19, 2013 | 12:57 PM
Snoopysvet's Avatar
Snoopysvet
Your mom has a sweet ride!
Turbo-Rocket
Standard on Jetfire only... Turbocharged, fluid-injected. Aluminum V-8 construction, 10.25-to-1 compression ratio, 215hp, 215 cubic inch displacement, 300lb. ft. torque. Operates on premium gasoline.
Originally Posted by mrvette
My Mom's '63 Olds F85 with the old 215 ci Aluminum V8, sat in the garage from roughly '66 till '87.....with 35k on the clock, tank full of gas so after 20 years, upon rebuilding the carb, and brakes, car fired right up, ran rough as a cob, but did not quit.....filled with fresh gas, as tank had evaporated to about 1/2 tank....ran much happier....never even changed the wires.....
SO all this crap about gasoline deterioration I think is more about the specifics of the storage, and maybe a bit with the ethanol.....and I have some other stories about my opinions/and WHY....but that's another topic.....
Old Nov 19, 2013 | 04:51 PM
7t9l82's Avatar
7t9l82
i agree alot of this gasoline deterioration stuff is overblown however, gasoline is blended differently than 20 30 and 40 years ago( lead) different seasons have different blends different altitudes different states all affect the product . one would think all of that has to affect the stability of our fuel.
Old Nov 19, 2013 | 08:18 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Originally Posted by jnb5101
and it fired right up for the first time in 5 years.
I need for you to REALLY CONCENTRATE............................. ..........
"WHAT BRAND OF GAS DID YOU PUT IN THE CAR 5 YEARS AGO?"
(Whatever it is-----that's all I'm going to use from now on )
Old Nov 20, 2013 | 06:52 AM
bashcraft's Avatar
bashcraft
Why would you think that?
Old Nov 20, 2013 | 07:42 AM
Marlin's Avatar
Marlin
The gas in my 73 was probably 3 years old when I got it. I drove it to the gas station and topped it off and works fine. First 1/2 miles or so was a little rough not sure if it was age or the gas but no problems since.
Old Nov 22, 2013 | 02:05 AM
Korevette's Avatar
Korevette
I have had 'stabalizer' gell in two stroke gas tanks.
My Stihl chainsaw dealer has recommended 91 octane. I have used the same in 4 stroke engines on my rototiller and lawnmower with no problems.
To "keep sane-just drain". I can't stand 'gas shelac'.
I have had C12 fuel in my drag car while sitting for three years and it will still fire although that leaded fuel can eat hoses. The upside about that is I have not lost a race in the same amount of time.
Old Nov 22, 2013 | 10:53 AM
Mike Ward's Avatar
Mike Ward
Did you ask your dealer why higher octane would make a difference?
Old Nov 22, 2013 | 11:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by doorgunner
...I need for you to REALLY CONCENTRATE..."WHAT BRAND OF GAS DID YOU PUT IN THE CAR 5 YEARS AGO?"...
A better question would be what was the price per gallon at that time.
Old Nov 22, 2013 | 11:39 AM
Iceaxe's Avatar
Iceaxe
Gasoline deterioration is all just a myth, overblown, urban legend, no big deal, fun and games.... right up to until it bites you in the *** and you are forced to clean a fuel system.
Here is a pretty good article on gasoline deterioration
http://www.cnn.com/2008/LIVING/wayof...09/aa.bad.gas/
Old Nov 22, 2013 | 11:59 AM
Mike Ward's Avatar
Mike Ward
Wow. CNN- universally recognized as a credible source of automotive technical info.
Old Nov 22, 2013 | 01:42 PM
Ontario73's Avatar
Ontario73
Now that there is funny!
Old Nov 22, 2013 | 02:53 PM
Easy Mike's Avatar
Easy Mike
Can you say...Wolf Blitzer?
