How long Will Gas Last ?
Old Nov 17, 2013 | 10:26 AM
jnb5101's Avatar
jnb5101
Default How long Will Gas Last ?
When I moved from Florida to North Carolina (love it here), I had to store my 70 vert at my sister's house. The only preparation for storage in a hot Florida garage was some Sta-bil in the gas. This weekend I trailered it home. It hadn't been driven since it was garaged. I brought along tools to drain the tank, because I thought for sure the gas would have gelled. I used a Harbor Freight venturi siphon pump to remove any water condensate from the tank(there wasn't any) and noticed that the gas looked and felt good. I connected the new battery, disconnected the coil and cranked it about 30 seconds to pump up the oil pressure. Poured some of the siphoned gas into the carb, and it fired right up for the first time in 5 years.
Old Nov 17, 2013 | 10:44 AM
bashcraft's Avatar
bashcraft
I guess it'll last at least 5 years.
Mike Ward's Avatar
Mike Ward
Imagine that.
Now compare your experience with those that are convinced that gas goes bad before you leave the gas station parking lot.
Old Nov 17, 2013 | 10:50 AM
TedH's Avatar
TedH
I filled the tank of my Yamaha motorcycle in early 2012... and parked it when I bought a Harley in May, 2012. Stored it for winter with Seafoam additive winter 2012. Advance to November, 2013. The fuel has gelled and changed into varnish.
My guess: depends on the formulation. In my case, it is what Murphy sells with 10% ethanol.
I hear Shell and Conoco sell only 100% gasoline. That may make a difference.
Old Nov 17, 2013 | 10:54 AM
bashcraft's Avatar
bashcraft
I'd blame it on the seafoam.
Iceaxe's Avatar
Iceaxe
Normally fuel begins to deteriorate after about 3 month's. Adding a fuel stabilizer will extend the life to about 12 month's. After that it all depends on many other items and luck.
Small quantities of fuel deteriorate faster than large quantities. Your gas tank would not have worried me as much as fuel lines and carburetor, those are the real problem areas.
The good news is if the engines fires and you burn out the old gas and than burn some new gas the fuel additives in the new gas do a pretty good job of cleaning things out. But you really want to get the old gas out and get some freash gas flowing and cleaning the system ASAP.
Consider yourself lucky, after 5 years you could have had a real mess, adding the Sta-bil helped. You should have also fogged the motor which is simple and takes about 5 minutes. FWIW after adding Sta-bil you should drive the car to make certian the additive is present in the complete fuel system.
One other item is I always recommend you store a metal gas tank filled with gas as it reduces condensation in the tank and helps stops rust.
YMMV
Old Nov 17, 2013 | 11:14 AM
garygnu's Avatar
garygnu
I would add some fresh gas to mix with the old gas ,and drive the car a lot .I would be worried about old gas messing up the carb .
Old Nov 17, 2013 | 12:12 PM
Mike Ward's Avatar
Mike Ward
Best just do a frame off. Just in case.
Old Nov 17, 2013 | 12:26 PM
noonie's Avatar
noonie
jnb5101
I thought you used to be local.
All of the oil companies have recommendations on their website for longevity and storage despite all the myths of short or long term usability.
According to the oil companies, best is to store in a full tank, cooler weather the best and add a conditioner for long term storage. Sounds like that's what you did. You also didn't have E10 if you filled it in Florida 5 years ago.
I too have stored some cars for over 5 years and a couple, not all, have stunk so badly that it took a few weeks for the smell to get out of the ground where it leaked, and this was pre E10 stuff. These cars ran too, but I put in fresh gas, it gets burnt too.
Anyway, glad you are up and running, enjoy it.
Old Nov 17, 2013 | 12:35 PM
bluedawg's Avatar
bluedawg
Fuel sets in my vette, bikes and 4 wheelers for 6 months during the winter here with no issues, I was using stable, but don't any longer.
Old Nov 17, 2013 | 12:48 PM
FatCat's Avatar
FatCat
Hahahahahaha!!!
Old Nov 17, 2013 | 02:25 PM
7t9l82's Avatar
7t9l82
Old Nov 17, 2013 | 02:53 PM
mrvette's Avatar
mrvette
My Mom's '63 Olds F85 with the old 215 ci Aluminum V8, sat in the garage from roughly '66 till '87.....with 35k on the clock, tank full of gas so after 20 years, upon rebuilding the carb, and brakes, car fired right up, ran rough as a cob, but did not quit.....filled with fresh gas, as tank had evaporated to about 1/2 tank....ran much happier....never even changed the wires.....
SO all this crap about gasoline deterioration I think is more about the specifics of the storage, and maybe a bit with the ethanol.....and I have some other stories about my opinions/and WHY....but that's another topic.....
Old Nov 17, 2013 | 04:34 PM
jnb5101's Avatar
jnb5101
Mike, Fat cat, 7t9L82
I already did the frame off. Check 'my garage' for LiL Red. I think once per car is enough!
Old Nov 18, 2013 | 02:36 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Old Nov 18, 2013 | 03:02 PM
Mike Ward's Avatar
Mike Ward
Maybe just one or two more, you can never be 'too safe'.
Old Nov 18, 2013 | 03:16 PM
mac79vette's Avatar
mac79vette
From my experience its but to store the car with a full tank because the oxygen in the tank will cause the fuel to go bad quicker. My vette has been stored for long term twice while I was overseas, once for two years and once for four years. When I went for two years it was left with 1/8 tank and the fuel had thickened up and clogged the lines, filter and carburetor. When I stored it for four years it was with a topped off tank. After adding fuel to the carb it started and ran just fine without any problems.
To How long Will Gas Last ?
Old Nov 18, 2013 | 11:07 PM
Solid LT1's Avatar
Solid LT1
YMMV
I AGREE 100% with this statement
Old Nov 18, 2013 | 11:21 PM
qwank's Avatar
qwank
I just bought a 2001 Blazer that has been sitting for well over a year because the PO couldn't get it running. I got it running with the over year-old gas and it ran fine.
Old Nov 19, 2013 | 10:51 AM
rponfick's Avatar
rponfick
I'm with Mike Ward. I pull my engine to change the oil also. You can never be too careful. I got that from hanging around Lars too much.
Ralph
