Parking brake
Old Nov 17, 2013 | 07:17 PM
1qwk79's Avatar
1qwk79
Default Parking brake
I have a 79 that I am having an issue with the parking brake. I have good shoes on it, but the parking brake lever is pulled up all the way and will not hold. Also, parking brake light on dash stays on. I made the adjustment in the adjustment screw in the rotor, opening it up all the way and then backing it up 8 notches and I thing I need to make the adjustment at the y extension, any suggestions?
Old Nov 17, 2013 | 07:39 PM
BB2B's Avatar
BB2B
you are correct in your thinking. Once you have adjusted your brake shoes, you need to adjust the cables to get the lever travel correct.
Old Nov 17, 2013 | 09:00 PM
'75's Avatar
'75
Also be aware that the brake light can be turned on by the brake failure switch.
Old Nov 19, 2013 | 10:09 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
The parking brake cable will stretch with use and need to be retightened....Good Luck!
Old Nov 19, 2013 | 11:27 AM
oldC3guy's Avatar
oldC3guy
My parking brake cable had stretched so much that I ultimately bought a new one and went thru the adjustment routine. Works great now.
To Parking brake
