Another 383 build
Old Nov 18, 2013 | 05:56 PM
kanvasman's Avatar
kanvasman
Default Another 383 build
OK, I have a good block and crank for my 383. Want somewhere in 350-400hp neighborhood with good street manners. Plan on driving it a lot. I have a chance to pick up a pair of Trick Flow 30410001 SBC Aluminum heads for a really good price. No choice on cam yet since I want to get the heads right first. Would they be a good foundation to build on. I don't want to blow the budget or make some outrageous HP, just a little street rod '78 w 220R4 trans I already have. Thanks.
Old Nov 18, 2013 | 06:28 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
That part number is listed here. Pretty poor flow for a 195 head but will support 400 HP and 5500 RPM. http://www.users.interport.net/s/r/s...ehdc.htm#Chevy
Old Nov 18, 2013 | 06:37 PM
bluedawg's Avatar
bluedawg
If you can afford it spring for afr 180, will hit your target of 400 horse with a small enough cam to provide excellent street manners.
Old Nov 18, 2013 | 07:08 PM
StraubTech's Avatar
StraubTech
For the power you are wanting any 180 to 190cc head will work. I "freshened" a crate engine program for a company and that little 383 did quite well. Should be a thread on here about it.
Old Nov 18, 2013 | 08:17 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Check out a Howards roller kit in the .500 lift range and it will put you nicely above 400hp with a sweet torque curve...Dont make the mistake I did..I .built mine the first time under cammed with flat tappet thinking I wanted it streetable. It is now not only very streetable, but very powerful...
Old Nov 19, 2013 | 04:28 AM
kanvasman's Avatar
kanvasman
thanks for the replies. It appears that I am on the right track. More questions as I go along.
Old Nov 19, 2013 | 03:37 PM
glen242's Avatar
glen242
63mako or anyone else:
How much, actually, is 10 cfm flow or 20 cfm flow worth HP/Torque wise? Yes I know it depends on the rest of the engine, especially the cam, but how much is it worth using a cam of 0.500 lift and a duration of 230*@0.050? Is there any formula that can be used to determine that? I used the above numbers because those are the numbers for the CC XE274 flat tappet cam that I have in my 383.
Old Nov 19, 2013 | 03:40 PM
StraubTech's Avatar
StraubTech
cfm X .2575 X No. of cylinder = HP
To Another 383 build
