1973 clutch return spring
Old Nov 17, 2013 | 07:20 PM
troythefixer's Avatar
troythefixer
Default 1973 clutch return spring
hello, this is my first corvette and seem to be asking the simple questions, but when I pulled the engine I found that it had one long spring at the shaft to pedal linkage to pull the pedal back up, but reading some of the blogs it sounds like the spring or springs are actually on the clutch fork anybody got some help for me...Troy
Old Nov 17, 2013 | 07:25 PM
redvetracr's Avatar
redvetracr
the springs on the short pushrod & fork are anti-rattle springs, all the vendors show them in their online catalogs
Old Nov 17, 2013 | 08:24 PM
troythefixer
tks for the help, but is there also a spring at the pedal linkage...Troy
Old Nov 17, 2013 | 10:56 PM
Super6's Avatar
Super6
If it's like my '69, there is a hole for a spring in the Z-bar upright that the clutch pedal rod connects to and another hole on the metal reinforcement where the steering column comes through the firewall. The spring between these 2 points pulls the clutch pedal against the stop under the dash and takes the load off of the throw-out bearing.
Old Nov 18, 2013 | 07:04 AM
troythefixer
tks, I had found the one ine the z bar but could not find one on the body for the other end,,,,thankyou
Old Nov 18, 2013 | 04:28 PM
Alan 71's Avatar
Alan 71
Hi ttf,
Here's the spring connection at the firewall reinforcement. The tiny hole can be hard to find.
Regards,
Alan
Old Nov 18, 2013 | 08:34 PM
stevelischynsky's Avatar
stevelischynsky
Alan,
I'm always amazed by the pix you post on different threads. The lighting is always good. But the parts are always in fantastic shape as if you had the cars stored in a sealed nitrogen environment. The pix in this thread is an example of one of many that you have posted.
Steve L
73 coupe since new
Old Nov 19, 2013 | 04:11 PM
Alan 71's Avatar
Alan 71
Hi Steve,
Thanks for your comment!
My car was pretty carefully restored and is fortunate enough to be stored in a clean, dry, temperature conditioned, space. (Thanks to my wife!!)
Posting pictures is really the only payback I can offer for the pleasure this Corvette has given me for 42 years. Some pictures are 10-15 years old and some are brand new.
Regards,
Alan
To 1973 clutch return spring
