Inside rear view mirror replacement.
Old Nov 18, 2013 | 02:43 PM
Keith88's Avatar
Keith88
Default Inside rear view mirror replacement.
Anyone have a technique for removing and replacing the mirror/glass within the existing housing? I found one post where the guy just broke it with a hammer. I do have the replacement glass/mirror so saving the old glass isn't an issue.
Thanks.
Old Nov 18, 2013 | 07:42 PM
Brcmpbl's Avatar
Brcmpbl
Smashy smashy.
Carefully.
Old Nov 18, 2013 | 08:49 PM
Keith88's Avatar
Keith88
Lol. Ok, thanks.
Old Nov 18, 2013 | 09:13 PM
rafalc's Avatar
rafalc
Is your replacement an exact fit? I got mine from CC and its not the exact fit, I will need to take it to a glass shop to have it shaved down.
Old Nov 18, 2013 | 09:45 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I bought the entire mirror assembly. Pulled the old one of and and used the same mounting bracket for the new one, 5 minutes
Old Nov 18, 2013 | 10:31 PM
7T1vette's Avatar
7T1vette
Unless you have a unique or rare factory mirror option, you will be better off just replacing it. The repo's are almost identical and the prices are very reasonable. When I considered the same approach (replacing only the mirror glass), I found that disassembling one is no small task. Easier to replace it....one screw.
Old Nov 18, 2013 | 10:35 PM
Brcmpbl's Avatar
Brcmpbl
Should have mentioned - only reason I replaced the glass in mine is because it has a working map light that isn't reproduced to my knowledge. If it was a standard mirror I probably would have just replaced the whole thing.
If you've already bought the glass though, may as well take a stab at it.
Old Nov 19, 2013 | 02:56 PM
Keith88's Avatar
Keith88
Understood, but i am trying hard to keep as many of the car's original parts as possible - especially in the interior. I pryed back that rubber surround. That's a very thick piece of glass and not a matter of just dinging it with a small hammer. I decided to ship it off to Paragon as they will replace the mirror with my original housing.
Thanks to all that posted.
Old Nov 19, 2013 | 10:21 PM
Brcmpbl's Avatar
Brcmpbl
Good decision, nice to keep the original stuff where possible.
Old Nov 20, 2013 | 06:25 AM
brainsoft's Avatar
brainsoft
I bought a replica mirror and went to install it on the existing mount, thinking the same thing... 5 minutes. The new mounting slot is a hair narrower than the original mount so I've currently got an old flecked mirror in the car anda brand new one in a box
Old Nov 20, 2013 | 05:19 PM
7T1vette's Avatar
7T1vette
Chinese measurement skills...
Time to break-out the Dremel.
Old Nov 21, 2013 | 06:27 AM
brainsoft's Avatar
brainsoft
So good with numbers but so bad with rulers... ironic I guess
Old Nov 21, 2013 | 08:18 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Hold your horses for a second. If you're talking about just replacing the mirror glass, you may not have to break anything. I need to check if the map light is the same as the one on my 73, but on that one, the glass is held in place. with a rubber seal. I'll also try to find a post that I made on it.
First, the thread
http://forums.corvetteforum.com/c3-g...-a-mirror.html
Second, the mirror. Not terribly sure about he housing since I can't find a picture anywhere but the mirror glass itself is certainly available.
To Inside rear view mirror replacement.
