Tires ???
Old Nov 21, 2013 | 11:18 AM
Arny73's Avatar
Arny73
Default Tires ???
Was just wondering about tire size and handling for the front tire? I have 235/60/15 on front and rear ( came that way when I bought it) if I go yo a 235/70/15 on front would it handle better or worse.
Old Nov 21, 2013 | 11:27 AM
MelWff's Avatar
MelWff
The width of the tire is the same 235mm but the sidewall will be taller so I would think the ride would be slightly softer and the handling slightly less but I also do not think it will even be a noticeable seat of the pants difference.
Old Nov 21, 2013 | 04:52 PM
OzzyTom's Avatar
OzzyTom
What are you considering for the rear?
The 235/60/15 tyres are not as tall as the 235/70/15.
If you only change the front tyres it will raise the front of the car slightly.
Might look a bit funny with smaller diameter tyres at rear.
Old Nov 21, 2013 | 06:06 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by Arny73
Was just wondering about tire size and handling for the front tire? I have 235/60/15 on front and rear ( came that way when I bought it) if I go to a 235/70/15 on front would it handle better or worse.
OE tires for the later C-3s, after 1976, I seem to recall, were 225/70/15s, and in 1978, 255/60/15s were added as an option, both tires on 8" wide rims. (both of these tires are approximately 27" OD)
235/60, in reality are way too short, and 235/70s a little too tall. If the car is a daily driver type of car, I'd recommend the 225/70s all the way around. Your speedo will be accurate, and you'll be able to rotate the tires whenever necessary.
Old Nov 21, 2013 | 06:38 PM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
I agree with 225/70's all around.
Old Nov 21, 2013 | 07:15 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
60 aspect tires will tend to have better sidewall stability than 70's.
That said, IMCO any halfway serious discussion about better handling road tire fitments for 8" x 15" rims ought to include 245/60R15s or 255/60R15s. My $.02
Old Nov 21, 2013 | 11:07 PM
Glassbowtie77's Avatar
Glassbowtie77
255/60-15's on mine with no clearance problem and it handles well.
Old Nov 21, 2013 | 11:13 PM
warren87401's Avatar
warren87401
7th Gear
before i went to 17" wheels i ran 255/60/15 fronts and 295/50/15 on rear. granted the car has a complete vbp suspension upgrade but handling was amazing
Old Nov 22, 2013 | 08:03 AM
leadfoot4's Avatar
leadfoot4
I respectfully disagree, assuming you're saying a 60 series tire vs. a 70 series tire, on the same width rim, and the same OD, such as the sizes originally offered on a C-3. The 70 series tire, being narrower in section width, has it's sidewalls "stretched" to meet the beads of the rims, keeping them more perpendicular to the tread. The wider section width of the 60 series tire has it's sidewalls "pinched" to a rim that's almost too narrow for the tire.
As a part-time business, back in the mid 70s-early 80s, I used to sell tires. At the time, I had a '77 Pontiac T/A, and had a number of different tires on it, alternating between 225/70/15, 245/60/15, and 255/60/15s. The 225/70s and 255/60s were on the car "back to back" on the same 8" rims, and while the 60s looked 10X better, the 70s handled more crisply.
Old Nov 22, 2013 | 07:52 PM
TheSkunkWorks
To clarify, I was refering to tires with the same P#. And, FWIW I'm one of the guys who most frequently points out that TRA wheel width standards for 15" tires shouldn't be mistaken as recommending narrow wheels for performance applications.
In any event, IMOE once you get smaller than a 245/60R15 radial on an 8x15 rim you start moving past the point of diminishing returns as to any further increase of sidewall stability verses overall handling characteristics (including available traction). As for the 255s, they're noticeably better on 8.5x15 rims. YMMV
Old Nov 22, 2013 | 08:10 PM
7t9l82's Avatar
7t9l82
all i know is , i have 255-60-15 front and 275-60-15 rear cooper cobras . it handles well until, someone spits on the road then its donut city . i wonder if someone makes a 15" tire with better wet grip. i have 8.5 width rims.
Old Nov 23, 2013 | 09:00 PM
TheSkunkWorks
Avon CR6ZZ, but I would highly recommend putting the 245s on all four corners if the rims are all the same 8.5" width.
Old Nov 23, 2013 | 10:25 PM
3JsVette's Avatar
3JsVette
Interesting. Is that just your subjective opinion or did you do testing to come to those conculsions? I would have thought the lower aspect ratio with the wider contact patch would have more grip and therefore better response to steering input.
Old Nov 23, 2013 | 10:35 PM
7t9l82's Avatar
7t9l82
GULP!!! $1100.00 bucks a tire? anything cheaper like goodyear or hoosier?
Old Nov 24, 2013 | 08:54 AM
leadfoot4's Avatar
leadfoot4
That's my subjective opinion, since I didn't/don't have access to test tracks or testing equipment. A simple test, for those who have a mixture of tires on your cars...lean back and forth against a fender of your car and see how much the sidewall "rolls", and tries to roll the tread with it.. Compare the roll between the wider tire vs. the narrower tire....
Better yet, because the visual is easy, take a look at a current Formula 1 car's tire width compared to it's rim width. The sidewalls are stretched out to meet the rims, providing the maximum tread stability. I'm pretty sure that if a narrower rim, with the sidewalls "rolling in" to meet the rim provided greater cornering force, these "state of the art" race cars would be doing it.
FWIW, back in the 80s, when I was involved with an oval track car, we ran tires with a 13" tread width, mounted on a 15" wide rim. If a 10-11" wide rim would have worked better, we would have been running with them....
To Tires ???
