Who is running VS double offset trailing arms
Old Nov 23, 2013 | 06:11 PM
Gordonm's Avatar
Gordonm
Default Who is running VS double offset trailing arms
I bought mine in 2009 and am just now getting them dialed in. I did put them in about 2 years ago but just installed them without the alignment shims. I since have moved the car very little but now getting back to it. My question is do they have any washers or anything between the poly bushing and the alignment shims. The double offsets are different than the singles as they use a smaller bushing with no metal sleeve. Just the center sleeve for the bolt. It just does not seem right that the poly bushing is against the alignment shim but I may be wrong. There was no instructions and VS was closed this afternoon by the time I got around to calling. Have them somewhat apart. Anyone know the answer to this or do I wait and talk to VS Monday morning.
