Initial timing
Old Nov 26, 2013 | 02:10 PM
redwhitekat's Avatar
redwhitekat
Default Initial timing
I was just curious when you guys set up your total timing what did your initial timing end up at. My 74 ended up at 12 degrees
Old Nov 26, 2013 | 02:28 PM
lars's Avatar
lars
That's a good setup for a mild engine. The resulting initial will depend entirely on how long the advance curve is, so resulting initial with 36 total can be anywhere in the 8 to 24 degree range. A stock or very mild engine will run well with 8 to 16 degrees of initial. An engine with a bigger cam needs at least 18 initial. If you have a big cam and no vacuum advance, you want to get the initial up into the 24-degree range.
On my own solid-roller 408 with good combustion chambers, I'm running 24 initial, 32 total, and a very short (10-degree) vacuum advance curve to get my idle timing at 32 degrees.
But for your engine, the 12 initial will work great.
Lars
Old Nov 26, 2013 | 02:31 PM
redwhitekat
Thanks lars appreciate your help as always
Old Nov 26, 2013 | 04:11 PM
scottw's Avatar
scottw
I'm about 14.5 initial. Set the timing to be all in by 2800.
Old Nov 26, 2013 | 05:01 PM
hugie82's Avatar
hugie82
I'm about the same. If you experience pinging just back it off until it stops! Set it and forget it until next year
Old Nov 26, 2013 | 10:05 PM
scottyp99's Avatar
scottyp99
'80 'vette, L48, auto trans, with the timing set at 36 degrees @ 2800 rpm, it's at 16 at idle, with the vacuum advance disconnected. So the distributor gives 20 degrees of mechanical advance.
Check out this link:
http://www.gmheritagecenter.com/docs...t-Corvette.pdf
Page 74 tells what distributor came with what engine, and the specs for it. All sorts of other interesting little tidbits in there, too.
Scott
Old Nov 26, 2013 | 10:41 PM
redwhitekat
Nice article according to that they wanted at 8 degrees initial I wonder what they set the total timing in those days or did they go by sctricly initial timing ???
Old Nov 26, 2013 | 11:10 PM
scottyp99's Avatar
scottyp99
All you have to do is look at the centrifugal and vacuum advance specs right below that and do a little simple math.
Scott
Old Nov 27, 2013 | 07:13 AM
spikebot 81's Avatar
spikebot 81
Inital set at 20 deg, vac advance 14 deg, mech 15 deg. RHS cylinder heads. 60103 luanti cam. 9.5 to 1 compression. I do have traction issues at times
Old Nov 27, 2013 | 07:54 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
I just finished modding my mechanical advance to limit the total mech'l advance so I could increase my initial to 16* and still be all in at my target of 34* @ 3000 rpm.
To Initial timing
