Windshield woes
Old Nov 30, 2013 | 03:34 PM
BB2B's Avatar
BB2B
Default Windshield woes
Now that I have my windshield out and can clearly see the condition of the frame I am bummed. This does not look like a job for me. Top left corner has holes, bottom of upright on both sides have holes. I need an expert. Any recommendations for North Oakland county Michigan?
Old Dec 5, 2013 | 03:32 PM
ENCSDOUG's Avatar
ENCSDOUG
The Body shop that's working my 72 found the same issues after taking out the windshield. They sanded off the rust and treated the frame with a rust inhibitor. They used the fine fiberglass cloth, hardener and molded it to the frame. After some sanding and primer, you can barely tell it was done.
Old Dec 5, 2013 | 08:10 PM
stevelischynsky's Avatar
stevelischynsky
First time I've seen fiberglass to fill in holes on a windshield frame. Most weld up the holes.
Steve L
73 coupe since new
Old Dec 5, 2013 | 08:25 PM
VETFEVER's Avatar
VETFEVER
Steve L
73 coupe since new
If the amount of metal that's rusted away is miinimal it's not a bad idea - but if lot's of it is gone, you have a basic structural issue and it should be repaired with metal.
Old Dec 5, 2013 | 09:45 PM
Monty's Avatar
Monty
Do you have any pictures?
Paragon is in MI....they have the parts ans offer services.
I rebuilt my windshield frame from pairs of sides, corners, and the upper. If you can weld or have connections with someone that can, it's not that hard.
Old Dec 5, 2013 | 10:14 PM
1974ta's Avatar
1974ta
Default rust
Pictures would help a lot.
You can also use POR15 putty depending on the size of the holes.
It has an excellent tensile strength and is easy to use.
Without pictures it is really touch to make recommendations.
Welding is really not that big a deal depending on the extent of the rust.
Bill
Old Dec 6, 2013 | 07:31 PM
BB2B's Avatar
BB2B
I am attaching photos of the rusted areas. They don't clearly show the extent of the damage but the sections on the drivers side have holes approximately 1/2 inch in diameter.
Old Dec 7, 2013 | 08:42 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I would wire wheel or sand that rust to get a better idea of how badly the metal is rotted first, sometimes it can look a lot worse than it is. Anywhere you find holes, that needs to be fixed properly with metal.
Consider this: in the event of a roll-over, your windshield frame will help support the car. If it has rust damage, and that damage is "fixed" with anything other than welded-in metal, it might not help support the car anymore.
Old Dec 7, 2013 | 08:55 AM
jnb5101's Avatar
jnb5101
what does the back and under-side look like?
Old Dec 7, 2013 | 09:15 AM
bgrems's Avatar
bgrems
You could try Master Works in Madison Heights. They are a Corvette restoration and repair specialist.
It's South Oakland County, not North, but it is not too far away.
http://www.mwauto.com/index.php
Old Dec 7, 2013 | 10:49 AM
BB2B's Avatar
BB2B
Thanks for the feedback everyone. The only visible rust is on the windshield side of the frame. The other surfaces appear solid.
Old Dec 7, 2013 | 01:21 PM
7T1vette's Avatar
7T1vette
As mentioned, use a wire brush [wheel] on a power drill to clean off all the surface rust. Make sure you mask off the backside of the windshield frame to keep debris out of the interior. Also, quickly blow off stuff that lands on the paint; the rust debris will scratch the he!! out of your paint if you try to wipe it off.
Once done, you can see bare metal and make a good assessment of what needs to be repaired. If you have much rot, you really need to have metal stock pieced-in to maintain structural strength of the windshield frame.
There are "to-your-door" welding operators who can fix that damage at your home. It's a little more expensive, but well worth it in your case. Call around and get estimates, including travel costs.
Old Dec 7, 2013 | 01:59 PM
micks69's Avatar
micks69
Don't be bummed most vettes have some version of the rust you have some just have not discovered it yet.
Drivers upper corner should be replaced the rest looks salvageable with grinder and treatment. It doesn't appear structural as the strength is on the back side channels not the front sheet metal.
To Windshield woes
