T-Top triangular headed bolt removal help
Old Dec 2, 2013 | 04:58 AM
Jhiltonn's Avatar
Jhiltonn
Default T-Top triangular headed bolt removal help
Does anyone know what holds the backing plates, LH & RH Sides, in place inside the body of the car IF one removes the Triangular headed bolt and 2 associated screws?
I'm looking to replace mine as two of the screws aren't the correct size, and I'm replacing the outer SS plates with new ones, and I'd like to replace everything as per original specs.
Thanks!
Old Dec 2, 2013 | 08:52 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Jhiltonn
...Does anyone know what holds the backing plates, LH & RH Sides, in place inside the body of the car IF one removes the Triangular headed bolt and 2 associated screws?...
On some model years, they fall to the bottom.
Old Dec 2, 2013 | 10:37 AM
Mick71's Avatar
Mick71
St. Jude Donor '13-'14-'15,'21
They will on my '71. I made sure that I always left one screw in at all times when changing them.
Old Dec 2, 2013 | 03:44 PM
Alan 71's Avatar
Alan 71
Hi jh,
Originally the threaded plate for the wedge and 2 screws was held in place inside the lock pillar by tabs that are part of the birdcage.
They're are various reasons the tabs might let the plate fall, but they shouldn't. Sometimes the plate has been torqued so hard because the screws are frozen that it's been broken loose from the tabs.
If you need to replace the outer trim plate completely, (and can't use Mike 71s method), you can reach the threaded plate from the interior if the interior trim panel is removed. You can then hold the threaded plate in place to replace the screws and wedge.
Good Luck!
Regards,
Alan
You mentioned that you want to return the parts to "original specs"... the wedge, trim plate, and screws were chrome plated, not stainless steel.
Here's were you can yeah the threaded plate.
There's a little sly to reach through.
To T-Top triangular headed bolt removal help
