So after reading NUMEROUS posts from this forum and many others, including lars' procedure I'm going to be setting the lash tomorrow. As long as my crank socket gets here. But my question is this, right now my timing marks are dot to dot. Crank at 12 cam at 6. Both valves are closed on #1, my understanding is that I can do both valves now then rotate and move to #8. Am I correct?
From: Las Vegas - Just stop perpetuating myths please.
Something is wrong with your engine. Cam dot at 6 and crank dot 12 = both valves on #6 will be closed for firing and vlvs on #1 will be in overlap while both #1 and #6 are at TDC.
Do u have any profile information on your car to help us help u?
cardo0
Reason: unnecessary comment removed
Just use the process in the link I posted and you'll do just fine. You likely just didn't visually see that the valves were slightly off the seats on #1.
I'll be checking the geometry before I go thru the lash procedure. Hopefully I'll be able to check ptv tonight then I can start buttoning everything up. Just in time to drive it home and park it for the next 5 months or so. Lol
Dot to dot on timing chain is TDC compression stroke #6 cyl...Best to use this procedure on performance cams due to valve overlap. http://www.centuryperformance.com/va...procedure.html
I used this method when I did my hyd roller swap.My lifters called for 1/2 turn after 0 lash per the mfg. Did you degree your cam? I also advanced the cam 4 deg for better low end torque.If your running a solid cam and aluminum heads,Crane has a tech tip: http://www.cranecams.com/pdf-tech-tips/mech-lift.pdf
For flat tappet cams,their are now some lifters that will help lube the cam lobes...Crower cam saver lifters is one of them.I swapped in a roller and avoided all that break in,flat cam,type of oil needed hassles..
Had a friend with a BBC go through a wiped cam.Yup he followed all procedures,break in and high zinc oil.Cam lasted a few thousand miles then KAPUT!! Cam was mild,and was a complete kit .A roller swap is pricey but the gains and peace of mind are totally worth it.My 350 never ran better....Good Luck with your build...
IMO, the best and most accurate method to adjust valves is the EOIC method:
Exhaust valve starts to open, adjust intake valve.
Intake valve starts to close, adjust exhaust valve.
QUOTE=71454Chevelle;1585602699]IMO, the best and most accurate method to adjust valves is the EOIC method:
Intake valve starts to close, adjust exhaust valve.[/QUOTE]
the easiest and fastest way and you can start on any cylinder...no need to have the engine running either
EOI-ICE
