Half U Joint Grease Fitting
Old Dec 6, 2013 | 08:02 AM
micks69's Avatar
micks69
Default Half U Joint Grease Fitting
Is there a proper orientation for the grease fitting in the half shaft so they are reachable after installation?
Old Dec 6, 2013 | 08:17 AM
gcusmano74's Avatar
gcusmano74
Yes. Very important. Sometimes (on the driveshaft), if you get that orientation wrong, the grease fitting will bind against the yoke, and you will have to tear everything out and reinstall the Ujoint.
Like many things in my life, I found that out the hard way.
Old Dec 6, 2013 | 10:18 AM
Mike Ward's Avatar
Mike Ward
There isn't supposed to be grease fittings on these u-joints, it weakens them.
Old Dec 6, 2013 | 12:01 PM
micks69's Avatar
micks69
I'm not worried about 170 hp breaking them .
Old Dec 6, 2013 | 02:08 PM
jnealg's Avatar
jnealg
Myth, at least to the extent that most folks will use one.
I have put a heck of a lot more torque on grease fitting ujoints in my old jeep than most of these cars are.
bouncing up a hill on 40 inch tires will put a lot of torque on a joint. never had one fail due to the fitting.
Old Dec 6, 2013 | 02:10 PM
TWINRAY's Avatar
TWINRAY
I could never grease, even with the "needle" attachment, the zerks on h/s u joints so when I replaced them, I put the non-zerk joints on.
Old Dec 13, 2013 | 02:23 PM
Ely's Avatar
Ely
You are correct. That is a myth. You will not be failing the cross. If you are concerned about a cross fail.... Just be sure to put the zerk on the compression side of the cross. It is a trick that we used to advise the drag racers back in the day BEFORE the lube for life crosses were used.
Old Dec 13, 2013 | 03:05 PM
doctorgene's Avatar
doctorgene
Lots of Info in this thread. I Like to install the ones with no zerks, that way I don't get them on wrong. The Kiss theory, Keep It Simple, S. LOL Have a Safe & happy week-end. Gene
Old Dec 13, 2013 | 06:15 PM
DUB's Avatar
DUB
1000% AGREE. Put solid U-joints in it. I use Spicer U-joints and they can last at or around 70,000 miles....like many of my customers cars have proven I guarantee them for 5-year/50,000 miles when I install them.....that is how good they are. U-joints with a grease fitting are worthless in my opinion and that is what I am sticking with. They are weaker due to being cross-drilled.
DUB
Old Dec 13, 2013 | 06:20 PM
DUB's Avatar
DUB
OK...I can buy this...proven results speak a lot....but I still won't install then in a Corvette...because my luck...the one and only that would break...would be the one I installed and then I am fixing a lot more than a broken U-joint.
DUB
Old Dec 13, 2013 | 06:42 PM
bpassmore's Avatar
bpassmore
The real issue I have with zerked joints is the contamination that gets past the ball/spring seal in the zerk. A small amount gets past every time it is greased no matter how much you clean the zerk, a cap helps to prevent it, but how many use them? Pressure washing doesn't help at all.
Zerk joints never lasted as long as the non zerk joints on our rice combines. Torque was not an issue. (dust, dirt and moisture)= wear= failure.
Old Dec 14, 2013 | 02:52 PM
Ely's Avatar
Ely
It is true that the lube for life u-joint has a tighter fitting seal but a regreaseable u-joint can out last a lube for life joint if it is maintained correctly.
It is very important to remember that when you grease a Spicer u-joint you must purge ALL FOUR (4) of the seals. The seals are designed with this in mind. This purge process will flush out all of the contamination. Some times this is hard to do when installed in the car. If it is not done this way you are risking the burn up of the non purged trunnion.
To Half U Joint Grease Fitting
