202 heads
Old Dec 8, 2013 | 05:06 PM
bballboy06's Avatar
bballboy06
Default 202 heads
im looking at putting a pair of 202 heads on a 79 l-82
good ideas?
thoughts?
Old Dec 8, 2013 | 05:16 PM
bballboy06's Avatar
bballboy06
68-79
1.72/1.50
76cc
Old Dec 8, 2013 | 05:18 PM
garygnu's Avatar
garygnu
try some dart iron heads ,mite find a good deal on E-bay or at competition products.also get some long slot rocker arms .
Old Dec 8, 2013 | 06:03 PM
Solid LT1's Avatar
Solid LT1
L-82 had 2.02 heads late model lightweight casting and crack prone. You want better heads try some Vortec heads even though valves are smaller they outflow late model open chamber stuff. First valve to enlarge on a Vortec is exhaust valve.
Old Dec 8, 2013 | 06:36 PM
bballboy06's Avatar
bballboy06
somthing like this?
Vortec heads
58cc heads
170cc on the intake
1.94 heads
Roller tip rockers
Old Dec 8, 2013 | 08:48 PM
TedH's Avatar
TedH
If important to reuse your intake/carb/air cleaner, priced per head, assembled:
http://www.summitracing.com/parts/dr...1111/overview/
Old Dec 8, 2013 | 10:13 PM
7T1vette's Avatar
7T1vette
If your car is a 'driver' and you aren't looking for a lot of power, they will work just fine....especially if they are FREE.
Old Dec 8, 2013 | 11:09 PM
3origZlovers's Avatar
3origZlovers
Default ref: Heads
Everything else being good on your motor, I'd opt for a set of World Heads. 2.02/1.60 C.I. heads. They're good heads, strong and will work fine on chevy small blocks from 200 to 450 horsepower..employ a good intake and carb, and your're all set.
Old Dec 9, 2013 | 06:39 PM
bballboy06's Avatar
bballboy06
what about something like this?
65 chevy 350 double hump heads, 194 valves
Old Dec 9, 2013 | 07:04 PM
7t9l82's Avatar
7t9l82
what should be on an L-82 are better than any you listed. a vortec head may be o.k but just about any aftermarket head would be better
Old Dec 9, 2013 | 07:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
most the double hump heads dont have screw in studs or accessory holes in case you need them.
For the money those iron eagles are hard to beat and will outperform the double humps all day. Plus everythings new
Is it a budget thing that has you looking at used heads?
Old Dec 9, 2013 | 07:06 PM
7t9l82's Avatar
7t9l82
if a set of 882 heads aren't cracked by now they will probably be o.k.
Old Dec 9, 2013 | 08:21 PM
bballboy06's Avatar
bballboy06
it is more of a budget thing...
what should i pay for a pair or dart heads?
and none of the heads i mention are worth the money?
thanks
Old Dec 10, 2013 | 01:16 PM
scottyp99's Avatar
scottyp99
thanks
Yeah, none of those old heads are really worth the money, even if you get them for free. If you just want a set of cheap heads, take a look at this:
http://www.speedwaymotors.com/Flo-Te...lug,25118.html
740 bucks, brand-new aluminum heads from a reputable source. They won't perform like a lot of other, more expensive heads, but in a sub-1000 dollar head shootout, Car Craft said these perform about the same as Vortec heads, which is not bad. Definitely an improvement over an old, stock head. Edelbrock E-Street heads, and the dart SHP heads are worth looking at, too, a little pricier, but a little more performance, too.
Don't poo-poo the advantages that an aluminum head brings to the table, less weight, better heat dissipation, not to mention they are easier to lug around when installing them.
Scott
Scott
Old Dec 11, 2013 | 07:57 PM
wilcar's Avatar
wilcar
Summit 152123 are made by dart: cast iron large valve 72cc with screw in studs, .520 springs, and are assembled for $630 shipped to your door. I have a set on my carbed 1984 C4 and are great heads compared to some old rebuilt cast iron heads.
Old Dec 11, 2013 | 08:10 PM
3origZlovers
I agree with Scotty, spent a fortune trying to rebuild a set of heads off a '72 Corvette LT-1..even new valve seats, it was one thing after another (including one by the machine shop) $500 and nothing but a couple of boat anchors...decided on the world heads but dart would have been good too. Had no problems, have one set on a XE-268 cam engine and the other set on a Howard's Cam roller.
Old Dec 11, 2013 | 11:08 PM
XrayOne's Avatar
XrayOne
5th Gear
good ideas?
thoughts?
Both the L-82 and L-48 have 624's, the L-82 comes with 2.02's and four bolt mains. Aerohead is offering reconditioned Dart S/S heads very reasonable $$. Heart shaped chambers I believe. My 624's were milled and "pocket ported". Good luck.
To 202 heads
