Fire order
Old Dec 9, 2013 | 04:30 PM
robbys65's Avatar
robbys65
Default Fire order
HI GUYS
A FRIEND OF MINE HAVE REPLACED THE OLD SPARK PLUG CABLE WITH A NEW CABLE but he did a confusion with the numeration order.
Can you help me with a correct fire order and order of cilinder ???? CORVETTE C3 MADE 1972
Thanks in advance all of you
Robert
Old Dec 9, 2013 | 04:39 PM
BKbroiler's Avatar
BKbroiler
Firing order is 1-8-4-3-6-5-7-2
#1 cylinder is the front cyl on the drivers side. So 1-3-5-7 on driver side, 2-4-6-8 on passenger side.
Old Dec 9, 2013 | 05:15 PM
robbys65's Avatar
robbys65
Thank you very much.
Robert
Old Dec 9, 2013 | 05:29 PM
7T1vette's Avatar
7T1vette
Be aware that the location of the #1 plug wire in the distributor cap may be 'standard' or may have been re-clocked by a previous owner. Sometimes the wires need to be shifted one position in order to get the vacuum advance can positioned in a 'comfortable' place. If you are uncertain about that, you can crank the engine over to TDC (compression stroke) and pull the distributor cap off. The rotor will be positioned at the #1 cap terminal.
Old Dec 9, 2013 | 05:33 PM
robbys65's Avatar
robbys65
Thanks for your advice.
To Fire order
