Dead Cylinder Questions
Old Dec 9, 2013 | 06:18 PM
nomocrap's Avatar
nomocrap
Default Dead Cylinder Questions
On a 383 stroker I have a dead cylinder #2. With a heat sensing gun each header reads between 4 & 5 hundred degrees #2 reads 160 to 190. I have checked the spark plug, fires in another cylinder, moved the spark wire to another cylinder, fires, changed the distributor cap and rotor, cylinder still dead, ran a compression test on #2 cylinder, 150 lbs, checked valves on #2 appear to be moving the same on cylinders 4,6,8. I am baffled. HELP JAY
Old Dec 9, 2013 | 06:37 PM
wombvette's Avatar
wombvette
Compression, gas, fire. If you in fact have compression, and fire, not but one thing left.
Old Dec 9, 2013 | 10:00 PM
7T1vette's Avatar
7T1vette
Only two ways for it to not get fuel to #2 cylinder: 1) the intake valve is not opening; 2) there is a blockage in the #2 port on the intake manifold.
If it's not 'hot', it can't be firing. If it's not the plug, wire, cap or rotor, it must be getting spark. Getting spark but no fire = no fuel mixture in cylinder.
I would think that any blockage in the intake manifold would clear itself under the suction of the intake cycle. ???? More likely that the intake valve is not opening.
Old Dec 9, 2013 | 10:22 PM
billla's Avatar
billla
St. Jude Donor '14
I know you moved and checked the plug and wire, but check the ignition where it is by just hooking your inductive timing light to it - just fire it up, connect the light to the #2 wire and point it at your hand...if the light is flashing, the plug is firing and we move on. If it's not flashing, or flashing consistently, then we need to check the path: rotor->cap->wire->plug.
Next, pull the valve cover - easiest thing to check for is a pulled rocker stud, not at all uncommon in this vintage. If nothing's obvious, then pull the coil wire, have someone crank the engine, and watch the rockers on #2...and compare them to #4 - are they moving about the same amount?
If nothing comes from either of these, circle back and we'll look at other stuff
Old Dec 9, 2013 | 10:24 PM
garygnu's Avatar
garygnu
pull the valve cover and remove the spark plugs .have some one turn the crank over with a big ratchet .you will watch the push rods on #2 to see if they are moving the same as other cylinders .
Old Dec 10, 2013 | 06:51 PM
nomocrap's Avatar
nomocrap
Thanks I will remove the valve cover this week and check movement of valves. Afriend thinks the trigger in the distributor is not fireing this cylinder, is that possible? JAY
Old Dec 11, 2013 | 10:04 AM
7T1vette's Avatar
7T1vette
No. The distributor doesn't care which cylinder is getting the spark. That is determined by the distributor cap. The distributor cap contact could be bad, but you stated that it did the same thing with two different caps.
Old Dec 11, 2013 | 01:03 PM
hugie82's Avatar
hugie82
He said he changed the cap and rotor already....
I wiped out a cam a few years ago and the valve was still moving but I didn't figure it out until a week later and 50 miles before it got real bad. Then another cylinder dropped out and then I could see the difference in the rocker movement.
Either way, if the cam is wiped the damage is done! Catching it early will most likely save your bottom end. So you might want to get a micrometer with the magnet block to get a good reading on your valve lift.
Old Dec 12, 2013 | 01:54 AM
Gale Banks 80''s Avatar
Gale Banks 80'
If You think there is any chance of the cam being wiped have a look at the Oil Filter. The Cam Lifter might be in the Filter housing in little tiny bits. Its a quick and easy look.
Old Dec 12, 2013 | 07:52 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
You can get a "cheap" dial indicator ( a device that measures the amount of movement) -----you only need a cheap one unless you're going to be doing some serious engine rebuilding)------and set it on the top of the intake rocker arm--use a tool to rotate the engine by hand to check the total movement of the intake & then the exhaust valve---then compare those measurements to the spec. chart for your engine to determine if the cam lobes are wearing out.
Simple/easy to do after removing the valve cover---other cylinders can be checked also----write down the findings for future reference!
Old Dec 16, 2013 | 05:05 PM
nomocrap's Avatar
nomocrap
OK here is the progress. Valve cover pulled intake valves opening the same on pass side bank. Put in a different distributor. Removed carb a holley 4150 650 cfm, blew out all passages on carb. Today a friend loaned me a boriscope I will examine the the intake passage. I will report my findings. JAY
Old Dec 16, 2013 | 05:56 PM
diehrd's Avatar
diehrd
Is this motor popping out the carb or exhaust ? Aside form your heat test what else is going on when you drive it ??
Old Dec 18, 2013 | 03:58 PM
nomocrap's Avatar
nomocrap
The motor does not pop thru the carb. It runs smooth on the road. When I raise the RPM's the header for that cyl Heats up but runs cold at idle. I have rebuilt the carb, replaced the dist, verified the intake andexhaust valves for that cyl move the same as the other cylinders on that bank. A friend loaned me a boroscope but have not checked the intake passages yet. Will update on progress.JAY
Old Dec 18, 2013 | 04:36 PM
7T1vette's Avatar
7T1vette
OK. Here's one from "left field":
Is it possible that the spark plug threaded hole for that cylinder has been repaired with a Heli-Coil sometime in the past? If so...and if the mechanic decided to put epoxy on the Heli-Coil to assure that it stayed put...the spark plug would have little [or no] ground circuit with which to fire. The plug is grounded via the threads in that hole. If there was epoxy on the Heli-Coil threads, it would insulate them and prevent firing.
Old Dec 18, 2013 | 07:59 PM
diehrd's Avatar
diehrd
How does one think blockage with no adverse running conditions ? When you built the motor did you leave a rag in the intake ? Or had it tapped off ? If it is a blockage it must have been done when it was built and missed....
OR......Are you losing coolant ? Cause it sounds like it is at water temp.. So head gasket ? Which as i think about it makes a lot more sense then a blockage that causes no driving issue.
Old Dec 20, 2013 | 12:46 AM
bluedawg's Avatar
bluedawg
Youd think that it would also jump that gap. Does it apear to be heli coiled and appoxied?
Old Dec 20, 2013 | 01:39 AM
gkull's Avatar
gkull
Clamp your timing light to that cylinder. It will tell you if the wire is getting spark. cheap wires can get holes blown in them and they arc to the block instead of jumping the resistance of the plug. Fire the motor in a dark room and if it looks like a light show under your hood you are screwed.
Pull that plug out and lay it across the intake manifold and have your buddy crank the motor over in a darker setting. If the motor fires up it is fine. Just watch for the plug firing
You said the valves are opening so it only leaves one thing lack of spark or lack of spark at the correct time.
If you have the wires in the wrong order the plug could be firing on other than the compression stroke never heating the primary tube.
To Dead Cylinder Questions
Old Dec 20, 2013 | 01:42 AM
wombvette's Avatar
wombvette
A cylinder that doesn't fire at idle but fires at higher RPM indicates a lean condition, vacuum leak.
Old Dec 20, 2013 | 02:03 AM
bluedawg's Avatar
bluedawg
I was just curious as the epoxy/ helicoil you'd think that the spark wool still jump from the threads to the head.
Old Dec 20, 2013 | 09:54 AM
gkull's Avatar
gkull
That is a more than a little far fetched! the helicoil has to be touching the metal on metal in the threads somewhere. The spark from a plug can arc more than a 1/2 inch when you have bad wires. So the tiny width of epoxy is nothing
