Cabin Air help
Old Dec 13, 2013 | 10:21 PM
psycho dad's Avatar
psycho dad
Default Cabin Air help
My 76 has no air coming into the drivers compartment. All the ductwork is intact and I can hear the fan motor running. I was told there is probably a blockage, probably a rat's nest somewhere around the heater core.
If I get properly motivated and its not to cold this weekend I may go in to have a look. Before I start ripping out the console, is there anything else, possibly less invasive that I should check first?
thanks!
- Jay
Old Dec 13, 2013 | 10:40 PM
Hammerhead Fred's Avatar
Hammerhead Fred
thanks!
- Jay
If it's an A/C car the blockage will likely be on the up stream side of the evaporator coil as it is between the heater core and the blower. Check the intake area above the fan motor passenger side of the windshield. Over the years "stuff" builds up on the intake side of the evaporator eventually blocking all air. You likely can't see down in there easily but may be able to determine if there's a blockage. Mine had a bird's nest in there which had been blown up against the evap coil. Had to remove the evap case to clean it out. Time consuming but not the worst fix on the car.
Old Dec 13, 2013 | 10:47 PM
psycho dad's Avatar
psycho dad
we're practically neighbors, come help me!
I pulled back the screen and looked down toward the fan motor, nothing there. Sounds like you went in through the engine compartment and not through the dash?
Old Dec 14, 2013 | 12:09 AM
Hammerhead Fred
Way too cold to visit my neighbors near the beach
Yes, you go through the engine compartment should the evaporator coil be blinded with trash. To get to it you must remove the evaporate box from the engine side. Looks daunting but really not all that bad.
There's practically no way for something to get between the evaporator and the heater core. I suppose something could be blocking the air flow from the interior side of the heater but I've never seen it. If you pull your passenger dash and distribution box and get to the heater core finding nothing you'll know it's on the other side of the evaporator vs. the heater core. Once you get to the heater core fire up the blower - if nothing is coming through you'll need to move to the engine compartment.
Try pulling the blower motor and reaching down inside to see if you can locate something in front of the evaporator. Bring your double jointed elbow though. I taped a section of water hose onto the end of my vacuum cleaner and fished it into the cavity.
Pulled out lots of stuff but eventually not enough to fully restore the air flow. I think a bit larger & clear hose would have been an improvement - could get at the larger bits and see the stuff going through the hose.
Old Dec 14, 2013 | 08:16 AM
commander_47's Avatar
commander_47
On my 81, you can get in there through the upper right vent under the hood.
You may also be able to pull the kick panel on the passenger side.
Carefully snake a vacuum hose past the vent into the air box under the hood.
I pulled leaves an pinecones out of mine.
Old Dec 14, 2013 | 09:24 AM
psycho dad's Avatar
psycho dad
I like the vacuum idea, no disassembling.
Thanks for the help guys!
Old Dec 14, 2013 | 09:53 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Before I start ripping out the console, is there anything else, possibly less invasive that I should check first?...
Why not stay inside where you are warm and comfortable, and check the HVAC diagnostics page in the AIM? That will give you a clue where to begin your problem solving.
Old Dec 14, 2013 | 10:00 AM
psycho dad's Avatar
psycho dad
Lost my AIM when my old hard drive crashed. I'm combing the web of pictures now.
Old Dec 14, 2013 | 11:46 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Comb no more..
Old Dec 14, 2013 | 01:14 PM
psycho dad's Avatar
psycho dad
Thanks Ernie!
Old Dec 14, 2013 | 01:37 PM
0Willcox Corvette
Former Vendor
my pleasure..
It could be this too.. so if you get no where with the vacuum, pull the front duct and check the door.
To Cabin Air help
