Breaking in new Brakes....how??
Old Dec 19, 2013 | 11:29 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Default Breaking in new Brakes....how??
Just had 2 NEW front calipers installed along with new brake pads. I remember reading somewhere there's a right way and a wrong way to break in new brakes.....am I right or was I dreaming???
Old Dec 19, 2013 | 11:38 PM
billla's Avatar
billla
St. Jude Donor '14
The process depends on the type of pad - what's the brand and P/N?
Old Dec 19, 2013 | 11:41 PM
vetteguy75's Avatar
vetteguy75
Not sure but I do know that it's a stock caliper and organic pads. That's all I know for sure.
Old Dec 19, 2013 | 11:43 PM
vetteguy75's Avatar
vetteguy75
By the way...how long should the organic brake pads last. Mine is a boulevard cruiser...about 7000-8000 miles per year.
Old Dec 20, 2013 | 08:29 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If there are any specific break-in procedures, the folks who manufactured your pads should provide instructions on how you should break-in their pads.
Old Dec 20, 2013 | 08:54 AM
billla's Avatar
billla
St. Jude Donor '14
Go back to the shop and ask what the brand and P/N of the pads are.
Old Dec 20, 2013 | 09:26 AM
lurch59's Avatar
lurch59
A common procedure is the 30/30/30 rule, go from 30 mph to dead stop 30 times allowing 30 seconds between braking. Start out with light pedal pressure and end with moderate pedal pressure.
Technically speaking you should be running the same pads so that the same resin deposits on the rotor if they weren't turned. There are two types of braking, adhesion and abrasion. Laying down a new resin on the rotor should be similar to the old resin, this affects the adhesion. If the rotors were turned they should have been washed in soap and water.
Of course it is always good to check with the manufacturer, but the above break in should be fine for street use.
BTW, don't leave your foot on the brake pedal after hard use, it leaves excessive resin that is proud to the rotor face, which results in variable disc thickness, pedal pulsation and will eventually change the metallurgy to cementite which wears slower and even if the rotor is turned, the pulsation will return due to it being harder than the surrounding rotor metal.
I've done a modest amount of studying brake technology, there is likely someone here that knows a lot more than I do.
Old Dec 20, 2013 | 11:59 AM
donyue's Avatar
donyue
I would check with the pad manufacturer about the suggested break in procedure.
The good manufacturers such as Wilwood include the information with the pads.
My pads came with the information in the instruction sheet.
Old Dec 20, 2013 | 01:15 PM
75sl48's Avatar
75sl48
Regular pads don't need a break in last I knew. If they're ceramic like power stop or hawk or the sort then just Google the break in. For my stang it was like 30-5 with med pedal 5 times then 50-0 hard 5 times and let them cool between each stop
To Breaking in new Brakes....how??
