Brake Upgrade.....C5 vs Willwood
So, from the cool factor which one is better?
Which one is better performance?
Been waiting for this thread !! tnx
http://www.vbandp.com/auto-parts.htm...category_id=26
The only way to improve on the stock C3 brake system of 4 piston fixed calipers, front and rear, with 12 inch vented discs, front and rear, is to use a fixed 4 piston (or 6 piston front caliper) such as Baer/wilwood AND to increase the rotor diameter to 13/14 inch diameter-BIG BUCKS-approx $3,000. Unless you are racing, not sure of the benefit on the street.
A more prudent approach, IMCO, would be to make sure the stock system is operating correctly, paint the calipers whatever color you want (if cool is in the mix) along with drilled/slotted rotors (personally would not but just me and the issue of rotor runout in the rear), high performance brake pads, and Braided stainless steel flex lines, front and rear. Spend some money on the best ultra high performance tires you can afford and the car will stop on a dime!
With that said, on my 78 L-82, I use the stock calipers (painted silver), stock rotors, Braided Stainless steel flex lines, Performance Friction Carbon Metallic pads, and 255/45/17 ZR summer only tires-the car just stops like now when needed!
I recently upgraded two of my other car's brakes and went through the trouble since these were what I consider "upgrades". 94 Mustang GT convertible from stock 11 inch rotors/single piston floating calipers to Mustang Cobra brakes-13 inch Slotted rotors /dual piston Calipers with a cobra master cylinder, Performance Friction pads, SS lines-$500. #2 2008 Chrysler 300 3.5l V6 limited-Stock 12 inch rotor/single piston floating caliper- to Chrysler Hemi Brakes-13.6 inch Drilled/slotted rotors/MUCH bigger dual Piston floating Calipers with a brake pad 2X the size of the Limited's pads, SS brake lines and Performance Friction Pads-$400.
These two examples are to me "brake upgrades"!
Next up-daughters 2001 Pontiac Grand Prix. Stock front brakes are 11 inch rotors with a single piston floating calipers-currently using drilled/slotted rotors with PF pads. Going to F body 98-02 Camaro dual piston floating calipers, 01 impala 12 inch rotors, SS brake lines, and PF pads-Cost $350.
Hope that helps!
How about heat dissipation if you actually drive your car hard enough to need that sort of thing? No? No improvement with aluminum over cast iron?
Sorry, I stopped reading beyond that.
But what do I know.
But what do I know.
Is it me or did I not say the only real advantage is the aluminum versus the cast iron caliper in my comments above? In my opinion, not worth the advantage of heat dissipation and less unsprung weight for a street car.
I took the time to write my original comments, to dispel these kinds of myths about hydroboost "increasing clamping force".
But what do I know!
Some folks, for mis understood reasons, feel that if you have more piston area that you have more brake power. No, you just have the same forces available to you with less effort on the leg. In that same light you don't make more force by way of a larger rotor either. In that case you simply do it more effectively with greater mass for the thermal demand.
Maximum brake force remains the point of lock up of the tire to the road. No more, no less. With less piston are or smaller rotors you (meaning YOU) work harder applying leg pressure (line psi) to generate that max. With more pistons or larger discs the components aide that and the result is your leg doesn't work as hard.
Front: 13" 2-piece rotors with Wilwood Superlite calipers (4-piston fixed).
Rear: Stock rotors with Wilwood Dynalite calipers (also 4-piston fixed)
Had to switch to a 1" bore master cylinder as the Wilwood calipers have slightly smaller piston diameter. I used a stock MC for manual brakes (I have power brakes, the manual MC bolts right up).
I bought stuff in several iterations, so not sure about total cost. Probably a bit over $1K.
Todd - never mentioned piston area - was just referring to the hydroboost which as I just clarified, I was misunderstanding/remembering regarding clamping force applied at the caliper.
BUT for a big performance gain on the C3, one would have to opt for a system like the Baer 6 piston fixed front calipers with 14 inch rotors-$3,200-just looked it up.
FWIW, if someone does this and keeps the stock rear caliper you could run this same set up without the mc change. Use a 120-11329/330 caliper with only slightly less piston area as stock. Offset by the larger rotor diameter for bias.
I have the red Wilwood D8-4 calipers and EBC sport rotors front and back. My stock calipers started to leak and rather than rebuilding them or purchasing upgraded stock rotors I went with the D8-4.
I can't say if they perform better than the C5 calipers or not, however I think they look good and perform as good or better than stock. I know I won't have to worry about leaking seals anymore and aluminum doesn't rust like cast iron.
The lighter weight can't hurt and better heat dissipation is also a bonus. I also replaced my master cylinder with a Wilwood and all my rubber brake hoses with steel braided hoses.
I haven't installed a Hydroboost as I think the braking force is fine as I can lock up the brakes at will and it doesn't require anymore leg force than normal.
My car is not for racing but with the power modifications that I have added I felt that it only made sense to upgrade the brakes to be sure of reliability.
I wanted to be sure I could stop as best as possible without going with racing brakes which would not be the best for the street.
Ultimately each to their own on this issue, brakes are one of the highest safety priorities for me on any car! Not a place to try and save a few dollars.
JMHO
