Bolt size for engine mounts?
Old Jul 10, 2002 | 12:10 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Bolt size for engine mounts?
While removing the engine mount bolts I noticed that they seemed loose in their holes. I'm talking about the long bolts that go through the mount and the frame. I just want to confirm the correct size. The ones I have are 7/16 diameter coarse thread bolts with a 5/8 hex head and an 11/16 hex nut. This is on a '78. Can anyone confrim this?
[Modified by burners, 10:12 AM 7/10/2002]
Old Jul 10, 2002 | 12:30 PM
442olds's Avatar
442olds
Default Re: Bolt size for engine mounts? (burners)
sounds about right. Most all chevy mounts use a 7/16" bolt on the motor mounts. The reason they may feel slopply is that the hole in the frame is larger than 7/16 and the mount should have a slot built into it. This is for installation and just in case manufacturing tolerances were a little off.
Old Jul 10, 2002 | 12:32 PM
Kingt's Avatar
Kingt
That's what my 77 has. I would assume they are probably the same?
To Bolt size for engine mounts?
