Modified LS5 Dyno results
Old Dec 22, 2013 | 01:36 PM
Doug Brandon's Avatar
Doug Brandon
Default Modified LS5 Dyno results
Had a nice write up on my combo with some history. Apparently the post didn't stick, so I will list results with fewer words:
1971 original LS5, .30 over with 9.6 CR, mild hydraulic roller, professionally ported L36 intake, original heads with 2.19/1.88 valves and pro head port work, Stage 2 Q-Jet by Sean Murphy, 2" Hedman headers, MSD 6AL. Results beat my expectations: 362 rwhp at only 5,000rpm and 461 wrtq at 3,500 rpm.
I have had several combos in the car over the years (433 with L88 style cam, 433 with Torker II and mild Hyd, 496 with solid FT and LS6 intake and Alum GM heads). This combo I have now is my fav. Very street able, and shows you can make good power with low profile intake and a stock BB hood.
Old Dec 22, 2013 | 01:49 PM
bluedawg's Avatar
bluedawg
The 362 rwhp is nice, but the 461 rwtq is phenomenal.
Old Dec 22, 2013 | 04:44 PM
1977L48's Avatar
1977L48
with numbers like that i bet its a blast! you could even run like a 3.31 gear without OD, low torquing big blocks like that love to push against alittle gear!
Old Dec 23, 2013 | 10:36 AM
68post's Avatar
68post
With just a few more words , what are the roller specs if you don't mind ?
(..great HP , and outstanding torque !!)
Thanks.
Old Dec 23, 2013 | 11:28 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Is this an auto or stick car?
Jim
Old Dec 23, 2013 | 12:09 PM
Doug Brandon
Originally Posted by 68post
with just a few more words , what are the roller specs if you don't mind ?
(..great hp , and outstanding torque !!)
thanks.
216/224 @ 050
516/544
112 lsa
Btw, engine assembly, head work, and dyno tune was done at Lamar Walden Auto in Doraville, GA. Lamar is near legend status in this area and is best known for his 409 work. Dyno is a Dynojet with CF SAE Smoothing.
Old Dec 23, 2013 | 12:16 PM
Doug Brandon
Jim
Jim,
You helped me years ago when I was building the 496 that I had in this car for a while. Decided to build the original motor, and need another project car for that 496! Nice to see you still peruse these boards. I have not been so diligent!
Original 4 speed car, but has a TKO 5 speed now.
Old Dec 23, 2013 | 01:38 PM
Les's Avatar
Les
That's just a helluva street engine you have there! Great combo of parts- the bigger valves & porting really let the other parts work together. Congrats on a sweet result. You really should get out to the drag strip and let it loose!
Old Dec 23, 2013 | 05:58 PM
427Hotrod's Avatar
427Hotrod
No doubt Lamar does great work. The word Legend fits him well. You've got a little Lamar Magic in that combo it sounds like.
I can't help myself..benchracing is almost as much fun as doing it!
JIM
Old Dec 24, 2013 | 08:22 AM
69ttop502's Avatar
69ttop502
Nice job Doug. Long time no see from over here in Athens. Let me know of any shows around you will be going to and lets get together. Do you still have the shop in Winder I think you said?
Bill VO
Old Dec 24, 2013 | 09:46 AM
427Hotrod's Avatar
427Hotrod
Man...you guys are making me think of by birth state...Georgia! Spent quite a few years around Greensboro/Maxey's area...lots of family still there.
OK..back to your regularly scheduled programming!
JIM
Old Dec 25, 2013 | 12:03 PM
69ttop502's Avatar
69ttop502
Didn't know you have roots here Jim. Would make a good shakedown trip for your new engine Jim. Come on down.
Bill
Old Dec 26, 2013 | 12:48 PM
Doug Brandon
Bill
Exactly. Need some big block vettes to get together in GA!!
To Modified LS5 Dyno results
