Alright, tomorrow once I get back from school I'll be pulling the intake off again to reseal it and make sure I don't get any vacuum leaks. I saw that when I had some spilled oil on the intake that right in the middle I have an exhaust leak through the exhaust crossover (no EGR on this manifold) and it was blowing bubbles. That's where I thought that since that was leaking, there's a pretty large chance the intake is leaking too.
Do you have anyone that would loan you a stock spreadbore intake to test with, because I doubt your carb adapter is causing the problem you're describing.
The carb to manifold mismatch is at the secondary bores with your adapter.
That is a great carb, I'd prefer it over a square bore holley.
I've used a Comp 262HE in a low compression 350 and it had plenty of low-end punch. I've got your current cam (262XE) on the shelf that was destined for a different low-comp 350 build.
Before you pull the intake. Disconnect and plug all the vacuum lines at the carb and intake except the vac advance can. Pull the line off the carb going to the vacuum advance can and suck on it. It should pull the advance plate and then you can't suck any air through it. That eliminates any leaks outside the intake/adapter/carb. Then check vacuum with your guage. If it jumps up to about steady 17.5 at 800 no load RPM the leak is not at the intake. If it don't increase spray a little carb cleaner around the base of the carb adapter and carb base. If it is leaking at the base you will rev a little when it sucks in the carb cleaner. If that all checks out you have a manifold leak.
I'm not running any vacuum accessories except for the break booster, heater control valve, and vacuum advance. Already blocked the line going to the heater control valve and no difference, and the vacuum advance canister is good. I'll check at the brake booster if I have a leak at the seal where it enters the booster. Thanks for the tips! I'll try everything again in a few minutes
You can buy the Performer RPM with a spreadbore flange (7104), in case you were not aware of that. Maybe you can clean it up thoroughly and return it? I don't think the adapter is the cause of your problem, but I still don't like them, especially the ones that adapt a spreadbore carb to a square flange. Anyway, looks like you have some good advice to work with here, and since you're planning to upgrade heads, you should have a rockin' little powerplant there when you are finished, good luck!
I fired her up today to find any possible vacuum leaks and I couldn't find any. What I did find however when I checked the temp on each header was that my #5 cylinder was wwaayyy colder then the rest and I found an arcing spark plug wire, so I'll be getting new wires. It didn't solve the vacuum problem but it did go out, it sits at 15 inches now. And I do have a good amount of power down low now but it still takes off stronger above 4000, so any tips on tuning the carb? I think that could possibly be it. I have it tuned a little richer then I had it before the cam swap, but I'm not expert on carbs.
Scott
Ive had the performer RPM with a square flange from another engine I bought for this car but ended up selling the block, crank, and pistons from it and kept the heads and intake. And since I had it, I thought I would might as well upgrade and replace the performer. The engine seems to make power up until 6k. Although it won't be seeing that with a stock bottom end.
I did not degree the cam, and I set it in with both timing dots matched together to make sure I get the valve timing right. And I made sure that I set the crank gear in the standard valve timing slot and not 4* advanced or 4* retarded. I just found a vacuum leak right behind the carb at the fitting that goes to the brake booster, and that brought my vacuum up to 16 inches
There ya go, now the power should come on much faster.
I hope the valve timing is ok, but with quality control the way it is nowdays it is really best to degree the cam to be sure.
I've not used any of the Comp XE cams in my engines yet,( my buddy's 396 - yes ), but the 262HE (212 @ .050) had more power below 4,000 than the 268HE (218 @ .050) in Comp's dyno curve.
yours should be at least between the two of those in my opinion. Probably closer to the old 268HE .
The Performer will probably give you a better feel of more bottom-end torque, but the RPM would probably run faster in the quarter mile. (hope that makes sense)
If i recall correctly I only had 15" of vaccum at an idle with the xe262h on my l48.
Reason: shittty spelling and dropped beer.
Fixing the vacuum leak and plug wire will help a lot. Have you recurved the distributor? That will make the biggest difference you will notice at the off idle to 3000 RPM range. Tuning the carb correctly will likely help the bottom end. Have you done any jet changes at all? The idle screws won't cut it. That just fattens up the idle circuit. Your gaining ground on it.
These two papers will help you out. Need a vacuum advance can that matches your new vacuum readings and a timing curve that is 36 degrees with vacuum advance disconnected and plugged all in @ 2800 or so. Then hook your correct vacuum can back up and let us know how it does. Don't mess with the carb until it is firing on all cylinders and the timing and curve are set up right. Then, and only then go through the carb. Here is a great link for that.
If you have good compression, no vacuum leaks and good spark to all cylinders and follow these papers you will have a great performing engine for not much cash investment, just time investment and you will learn a lot about performance tuning a carberated engine which is a lost art. Run the Performer intake as it matches your cam well. Cam operating range is 1300 to 5600. Performer operating range is idle to 5500.
Thanks for the links! Those will really help. It didn't even come to me that with reduced vacuum compared to stock the vacuum advance won't work as intended. I haven't driven it since I fixed the vacuum leak and tweaked the carb a bit so I can't say how its running, it started snowing again today . I haven't changed jet sizes yet because I'm still deciding if I'm going to change carbs in the spring to match the intake (plus shorten the height a bit). And yes, I did recurve the distributor, one of the first things I did because when I bought the car the vacuum advance didn't worked and had a massive leak (was basically a straw) and the mechanical advance in the distributor was siezed up and didn't move at all. I bought a recurve kit and used the weakest springs so the total advance at 2500rpm was 36 degrees. And so I should for sure run the performer instead of the RPM? I'll sacrifice just a bit of bottom end for an increased 1/4 mile with this cam, plus I feel that the rpm will help me with new heads this summer
Update: I love the new cam. I got the vacuum issues sorted out which all came from around the carb and then one from the headlight switch (left it connected but disconnected/plugged the line up by the actuators). The thing pulls a lot harder now once it hits 2000 rpm. I know it should lower, I just don't have the carb tuned anywhere near perfect (jets and accelerator arm). Its 10 degrees out now so no rush. Its a lot closer to what I'm looking for out of it, hopefully the heads will bring it right up to where I want it.
What do I need in order to bring the stock 8.5:1 compression up to around 10:1 ratio? THin head gaskets? If I get everything planned out, I'll possibly do this all within a month or two. What do the intake runner sizes mean on heads? I'm assuming that higher revving, bigger engines need bigger size ports.
(Should I be starting a new thread?... This started as just choosing a cam, and I'm ending up replacing everything but my bottom end)
If your compression ratio is actually 8.5:1 right now, then a Felpro 1094 head gasket, .015" compressed thickness, along with some 64cc combustion chamber heads, should get you somewhere around 9.5:1. Your present compression ratio is probably more like 8:1 now, so you're probably looking at about 9:1 with the new heads and gasket. If you could find some heads with 58cc chambers, you'd be looking at closer to 9.5:1. If you want to go higher than that, you're looking at milling heads, or buying new flat-top pistons.
