Power Antenna Problem
Old Jul 10, 2002 | 05:07 PM
roscoedog's Avatar
roscoedog
4th Gear
Default Power Antenna Problem
The power antenna was working just fine until a week ago then all of a sudden nothing. No up, no down, no noise, -------nothing. I thought that maybe it was a fuse or circuit breaker. I have the original owners manual for my 78 SA but I cannot find a fuse or circuit breaker indicated for the antenna on the fuse chart. Thanks in advance, Bob
Old Jul 10, 2002 | 05:44 PM
fontking1a's Avatar
fontking1a
Default Re: Power Antenna Problem (roscoedog)
Sometimes the leads get corroded and sometimes the antennas just fill up with water and rust. If it's the leads, just shine 'em up with fine sandpaper...if it's water....time for a new antenna. If it's something else....???????
Old Jul 10, 2002 | 06:24 PM
Pete79L82's Avatar
Pete79L82
It is on the same 20 amp fuse as the clock, lighter and dome light. There is a relay that is mounted by the emergency brake handle. When you turn the radio off and on you should be able to hear it click. If you can hear it click then your problem is in the antenna or rear wiring. If you can not hear it click then your problem is fuse, radio, relay or forward wiring.
To Power Antenna Problem
